<config evaluator="node-type" condition="ds:dsDSP"> <forms> <form> <edit-form template="/3-column-edit-form.ftl" /> <field-visibility> <show id="ds:CustomerName" force="true"/> <show id="ds:CustomerPhone" force="false"/> <show id="ds:CustomerEmail" force="false"/> <show id="ds:ProjectManagerName" force="true"/> <show id="ds:ProjectManagerPhone" force="false"/> <show id="ds:ProjectManagerEmail" force="false"/> <show id="ds:DeveloperName" force="true"/> <show id="ds:DeveloperPhone" force="false"/> <show id="ds:DeveloperEmail" force="false"/> </field-visibility> <appearance> <set id="" appearance="bordered-panel" label="Properties: DSP" /> <set id="ds-dscontacts" appearance="fieldset" label="Contacts"/> <field id="ds:CustomerName" label="Customer Name" set="ds-dscontacts" /> <field id="ds:CustomerPhone" label="Customer Phone" set="ds-dscontacts"> <control template="/org/alfresco/components/form/controls/textfield.ftl"> <control-param name="size">14</control-param> </control> </field> <field id="ds:CustomerEmail" label="Customer Email" set="ds-dscontacts" > <control template="/org/alfresco/components/form/controls/textfield.ftl"> <control-param name="size">14</control-param> </control> </field> <field id="ds:ProjectManagerName" label="Project Manager Name" set="ds-dscontacts" /> <field id="ds:ProjectManagerPhone" label="Project Manager Phone" set="ds-dscontacts" > <control template="/org/alfresco/components/form/controls/textfield.ftl"> <control-param name="size">14</control-param> </control> </field> <field id="ds:ProjectManagerEmail" label="Project Manager Email" set="ds-dscontacts"> <control template="/org/alfresco/components/form/controls/textfield.ftl"> <control-param name="size">14</control-param> </control> </field> <field id="ds:DeveloperName" label="Developer Name" set="ds-dscontacts" /> <field id="ds:DeveloperPhone" label="Developer Phone" set="ds-dscontacts" > <control template="/org/alfresco/components/form/controls/textfield.ftl"> <control-param name="size">14</control-param> </control> </field> <field id="ds:DeveloperEmail" label="Developer Email" set="ds-dscontacts" > <control template="/org/alfresco/components/form/controls/textfield.ftl"> <control-param name="size">14</control-param> </control> </field> </appearance> </form> </forms> </config>
textfield.ftlThe textfield control renders a standard HTML text field.The parameters this controls supports are listed and explained below. None of these are used in 'view' mode. styleClass (optional, string): Allows a custom CSS class to be applied to the text field style (optional, string): Allows CSS rules to applied directly to the text field maxLength (optional, int): Defines the maximum number of characters the user can enter, maps directly to the standard HTML 'maxlength' attribute size (optional, int): Defines the number of characters the text field can display, maps directly to the standard HTML 'size' attribute activateLinks (optional, boolean): When set to "true" and the form is in "view" mode the control will attempt to display links as active hyperlinks forceEditable (optional, boolean): Forces the control to be editable, default is false
<div class="set"> <fieldset><legend>Contacts</legend> <div class="yui-gb"><div class="yui-u first"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_CustomerName">Customer Name:<span class="mandatory-indicator">*</span></label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_CustomerName" name="prop_ds_CustomerName" tabindex="0" type="text" value="" /> </div> </div> <div class="yui-u"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_CustomerPhone">Customer Phone:</label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_CustomerPhone" name="prop_ds_CustomerPhone" tabindex="0" type="text" style="width: 150px" value="" /> </div> </div> <div class="yui-u"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_CustomerEmail">Customer Email:<span class="mandatory-indicator">*</span></label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_CustomerEmail" name="prop_ds_CustomerEmail" tabindex="0" type="text" style="width: 150px" value="" /> </div> </div> </div> <div class="yui-gb"><div class="yui-u first"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_ProjectManagerName">Project Manager Name:<span class="mandatory-indicator">*</span></label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_ProjectManagerName" name="prop_ds_ProjectManagerName" tabindex="0" type="text" value="" /> </div> </div> <div class="yui-u"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_ProjectManagerPhone">Project Manager Phone:</label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_ProjectManagerPhone" name="prop_ds_ProjectManagerPhone" tabindex="0" type="text" style="width: 150px" value="" /> </div> </div> <div class="yui-u"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_ProjectManagerEmail">Project Manager Email:<span class="mandatory-indicator">*</span></label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_ProjectManagerEmail" name="prop_ds_ProjectManagerEmail" tabindex="0" type="text" style="width: 150px" value="" /> </div> </div> </div> <div class="yui-gb"><div class="yui-u first"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_DeveloperName">Developer Name:</label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_DeveloperName" name="prop_ds_DeveloperName" tabindex="0" type="text" value="" /> </div> </div> <div class="yui-u"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_DeveloperPhone">Developer Phone:</label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_DeveloperPhone" name="prop_ds_DeveloperPhone" tabindex="0" type="text" value="" size="14" /> </div> </div> <div class="yui-u"> <div class="form-field"> <label for="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_DeveloperEmail">Developer Email:</label> <input id="template_x002e_edit-metadata_x002e_edit-metadata_x0023_default_prop_ds_DeveloperEmail" name="prop_ds_DeveloperEmail" tabindex="0" type="text" value="" size="14" /> </div> </div> </div> </fieldset>
http://localhost:8080/share/res/css/base.css * (line 4) { margin-top: 0pt; margin-right: 0pt; margin-bottom: 0pt; margin-left: 0pt; } .sticky-wrapper select, .sticky-wrapper input[type="text"], .sticky-wrapper input[type="password"], .sticky-wrapper textarea, .yui-panel-container select, .yui-panel-container input[type="text"], .yui-panel-container input[type="password"], .yui-panel-container textarea (line 455) { padding-top: 2px; padding-right: 2px; padding-bottom: 2px; padding-left: 2px; width: 15em; } .form-field input[type="text"] (line 468) { width: 30em; } http://localhost:8080/share/res/components/form/form.css .form-container input (line 31) { clear: both; width: 30em; } http://localhost:8080/share/res/css/yui-fonts-grids.css .alfresco-share .sticky-wrapper select, .yui-panel-container select, .alfresco-share .sticky-wrapper input, .yui-panel-container input, .alfresco-share .sticky-wrapper textarea, .yui-panel-container textarea, .alfresco-share .sticky-wrapper button, .yui-panel-container button (line 32) { font-family: arial,helvetica,clean,sans-serif; font-style: normal; font-variant: normal; font-weight: normal; font-size: 99%; line-height: normal; font-size-adjust: none; font-stretch: normal; -x-system-font: none; } http://localhost:8080/share/res/themes/default/presentation.css .sticky-wrapper input[type="text"], .sticky-wrapper input[type="password"], .sticky-wrapper textarea, .sticky-wrapper select, .yui-panel-container input[type="text"], .yui-panel-container input[type="password"], .yui-panel-container textarea, .yui-panel-container select, .form-element-border, .share-form .yui-dt table (line 472) { border-top-width: 1px; border-right-width-value: 1px; border-right-width-ltr-source: physical; border-right-width-rtl-source: physical; border-bottom-width: 1px; border-left-width-value: 1px; border-left-width-ltr-source: physical; border-left-width-rtl-source: physical; border-top-style: solid; border-right-style-value: solid; border-right-style-ltr-source: physical; border-right-style-rtl-source: physical; border-bottom-style: solid; border-left-style-value: solid; border-left-style-ltr-source: physical; border-left-style-rtl-source: physical; border-top-color: #c5d6e2; border-right-color-value: #c5d6e2; border-right-color-ltr-source: physical; border-right-color-rtl-source: physical; border-bottom-color: #c5d6e2; border-left-color-value: #c5d6e2; border-left-color-ltr-source: physical; border-left-color-rtl-source: physical; font-weight: normal; }
<div class="form-field"> <#if form.mode == "view"> <div class="viewmode-field"> <#if field.mandatory && !(field.value?is_number) && field.value == ""> <span class="incomplete-warning"><img src="${url.context}/res/components/form/images/warning-16.png" title="${msg("form.field.incomplete")}" /><span> </#if> <span class="viewmode-label">${field.label?html}:</span> <#if field.control.params.activateLinks?? && field.control.params.activateLinks == "true"> <#assign fieldValue=field.value?html?replace("((http|ftp|https):\\/\\/[\\w\\-_]+(\\.[\\w\\-_]+)+([\\w\\-\\.,@?\\^=%&:\\/~\\+#]*[\\w\\-\\@?\\^=%&\\/~\\+#])?)", "<a href=\"$1\" target=\"_blank\">$1</a>", "r")> <#else> <#if field.value?is_number> <#assign fieldValue=field.value?c> <#else> <#assign fieldValue=field.value?html> </#if> </#if> <span class="viewmode-value"><#if fieldValue == "">${msg("form.control.novalue")}<#else>${fieldValue}</#if></span> </div> <#else> <label for="${fieldHtmlId}">${field.label?html}:<#if field.mandatory><span class="mandatory-indicator">${msg("form.required.fields.marker")}</span></#if></label> <input id="${fieldHtmlId}" name="${field.name}" tabindex="0" <#if field.control.params.password??>type="password"<#else>type="text"</#if> <#if field.control.params.styleClass??>class="${field.control.params.styleClass}"</#if> <#if field.control.params.style??>style="${field.control.params.style}"</#if> <#if field.value?is_number>value="${field.value?c}"<#else>value="${field.value?html}"</#if> <#if field.description??>title="${field.description}"</#if> <#if field.control.params.maxLength??>maxlength="${field.control.params.maxLength}"</#if> <#if field.control.params.size??>size="${field.control.params.size}"</#if> <#if field.control.params.width??>style="width:${field.control.params.width}px"</#if> <#if field.disabled && !(field.control.params.forceEditable?? && field.control.params.forceEditable == "true")>disabled="true"</#if> /> <@formLib.renderFieldHelp field=field /> </#if> </div>
