HelloAfter a user deleted some important datas, I had to reinstall Alfresco from backups. I choosed to reinstall, the software itself ( Alfresco 2.1), the postgres database, and the contentstore.I configured index.recovery.mode=FULL in the repository.properties, and I see from the tomcat logs that the indexes are rebuilt.maintenance@dakar:/srv/alfresco_data$ tail -f /opt/alfresco-2.1.0/tomcat/logs/catalina.out
10:16:17,234 INFO [node.index.FullIndexRecoveryComponent] 20 % complete.
10:17:12,781 INFO [node.index.FullIndexRecoveryComponent] 30 % complete.
10:18:15,478 INFO [node.index.FullIndexRecoveryComponent] 40 % complete.
10:19:50,181 INFO [node.index.FullIndexRecoveryComponent] 50 % complete.
10:21:19,934 INFO [node.index.FullIndexRecoveryComponent] 60 % complete.
10:22:50,441 INFO [node.index.FullIndexRecoveryComponent] 70 % complete.
10:23:57,186 INFO [node.index.FullIndexRecoveryComponent] 80 % complete.
10:25:07,464 INFO [node.index.FullIndexRecoveryComponent] 90 % complete.
10:26:30,864 INFO [node.index.FullIndexRecoveryComponent] 100 % complete.
10:26:30,871 INFO [node.index.FullIndexRecoveryComponent] Index recovery completed.
however after that CPU stays at 100 % , and it 's not possible to shutdown tomcat with bin/shutdown.sh( I get maintenance@dakar:/srv/alfresco_data$ tail -f /opt/alfresco-2.1.0/tomcat/logs/catalina.out
maintenance@dakar:/srv/alfresco_data$ less /opt/alfresco-2.1.0/tomcat/logs/catalina.out
maintenance@dakar:/srv/alfresco_data$ /opt/alfresco-2.1.0/tomcat/bin/shutdown.sh
Using CATALINA_BASE: /opt/alfresco-2.1.0/tomcat
Using CATALINA_HOME: /opt/alfresco-2.1.0/tomcat
Using CATALINA_TMPDIR: /opt/alfresco-2.1.0/tomcat/temp
Using JRE_HOME: /usr/lib/jvm/java-6-sun-1.6.0.24/
01.03.2011 11:52:07 org.apache.catalina.startup.Catalina stopServer
SCHWERWIEGEND: Catalina.stop:
java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:35
) I have to kill the java process. manually.Is something going wrong in the index recovery ?
