Hello to everyone! I have created a custom workflow that works perfectly but I can not see in the manage task, the properties that i have define in property- sheet. maybe i don't properly configure the workflow model and the file web-client-config-custom?please help me!these are the 2 files:pm-model.xml
<model name="wfpm:workflowpmmodel" xmlns="http://www.alfresco.org/model/dictionary/1.0">
<description>Workflow VeV Model for PM</description>
<author>giustino - labbate</author>
<version>1.0</version>
<imports>
<import uri="http://www.alfresco.org/model/dictionary/1.0" prefix="d" />
<import uri="http://www.alfresco.org/model/dictionary/1.0" prefix="cm" />
<import uri="http://www.alfresco.org/model/bpm/1.0" prefix="bpm"></import>
</imports>
<namespaces>
<namespace uri="wfpm.model" prefix="wfpm" />
</namespaces>
<constraints>
<constraint name="wfpm:status" type="LIST">
<list>
<value>Redatto</value>
<value>In Verifica</value>
<value>Verificato</value>
<value>Validato</value>
</list>
</parameter>
</constraint>
</constraints>
<types>
<type name="wfpm:inizia">
<parent>bpm:startTask</parent>
<mandatory-aspects>
<aspect>wfpm:status</aspect>
</mandatory-aspects>
</type>
<type name="wfpm:verificaTask">
<parent>bpm:workflowTask</parent>
</type>
<type name="wfpm:nonVerificatoTask">
<overrides>
<property name="bpm:packageItemActionGroup">
<default>edit_package_item_actions</default>
</property>
</overrides>
</type>
<type name="wfpm:validazioneTask">
</type>
<type name="wfpm:RifiutatoTask">
<overrides>
</property>
</overrides>
</type>
<type name="wfpm:ValidatoTask">
</type>
</types>
<aspects>
<aspect name="wfpm:status">
<title>Stato del documento</title>
<properties>
<property name="wfpm:status">
<type>d:text</type>
<default>Redatto</default>
<constraints>
<constraint ref="wfpm:status" />
</constraints>
</property>
</properties>
</aspect>
<aspect name="wfpm:utente">
<title>Utente</title>
<properties>
<property name="wfpm:utente">
<title>Utente validazione</title>
<type>d:text</type>
</property>
</properties>
</aspect>
<aspect name="wfpm:valiDate">
<title>validazione</title>
<properties>
<property name="wfpm:valiDate">
<title>Data validazione</title>
<type>d:date</type>
</property>
</properties>
</aspect>
</aspects>
</model>
web-client-config-custom.xml
<alfresco-config>
<config evaluator="node-type" condition="wfpm:inizia" replace="true">
<property-sheet>
<separator name="sep1" display-label-id="general" component-generator="HeaderSeparatorGenerator" />
<show-property name="bpm:workflowDescription" component-generator="TextAreaGenerator" />
<show-property name="bpm:workflowPriority" />
<show-property name="bpm:workflowDueDate" />
<show-property name="wfpm:status" read-only="true"/>
</property-sheet>
</config>
<config evaluator="node-type" condition="wfpm:VerificaTask" replace="true">
<property-sheet>
<separator name="sep2" display-label-id="general" component-generator="HeaderSeparatorGenerator" />
<show-property name="bpm:taskId" />
<show-property name="bpm:description" component-generator="TextAreaGenerator" read-only="true"/>
<show-property name="bpm:dueDate" read-only="true"/>
<show-property name="bpm:priority" read-only="true"/>
<show-property name="bpm:comment" />
<show-property name="bpm:status" />
</property-sheet>
</config>
<config evaluator="node-type" condition="wfpm:nonVerificatoTask" replace="true">
<property-sheet>
<separator name="sep4" display-label-id="general" component-generator="HeaderSeparatorGenerator" />
<show-property name="bpm:description" component-generator="TextAreaGenerator" />
<show-property name="bpm:dueDate" />
<show-property name="bpm:priority" />
</property-sheet>
</config>
<config evaluator="node-type" condition="wfpm:ValidazioneTask" replace="true">
<property-sheet>
<separator name="sep6" display-label-id="general" component-generator="HeaderSeparatorGenerator" />
</property-sheet>
</config>
<config evaluator="node-type" condition="wfpm:RifiutatoTask" replace="true">
<property-sheet>
<separator name="sep7" display-label-id="general" component-generator="HeaderSeparatorGenerator" />
</property-sheet>
</config>
<config evaluator="node-type" condition="wfpm:ValidatoTask" replace="true">
<property-sheet>
<separator name="sep5" display-label-id="general" component-generator="HeaderSeparatorGenerator" />
</property-sheet>
</config>
<config evaluator="aspect-name" condition="wfpm:status" display-label-id="statoDocumento">
<property-sheet>
<separator name="sep3" display-label-id="detailswf" component-generator="HeaderSeparatorGenerator" />
<show-property name="wfpm:status"/>
</property-sheet>
</config>
<config evaluator="aspect-name" condition="wfpm:utente" />
<property-sheet>
<show-property name="wfpm:utente"/>
</property-sheet>
</config>
<config evaluator="aspect-name" condition="wfpm:valiDate" />
<property-sheet>
<show-property name="wfpm:valiDate"/>
</property-sheet>
</config>
</alfresco-config>
at the moment i was working at the task "inizia" and the task "verifica" but with no success because at the task inizia the property(aspect) wfpm:status appears but not in read-only mode, while in the task verifica e every property i've defined doesn't appear! what i'm wrong? i use alfresco community 3.4.these are the images of the manage task of "inizia" and "verifica"http://img5.imageshack.us/img5/1381/iniziatask.jpghttp://img574.imageshack.us/img574/9434/verificatask.jpg
