Hi all, i have a problem that concerns with node Versioning in Alfresco.I try to explain my scenario: using the Java Foundation API, I want to create a version of a folder node and all its child (content) node. I'm doing that with the follow code:(Assuming that "folder" is for example the root folder Company_home)
// create PARENT node
NodeRef parent = nodeService.createNode(folder,
ContentModel.ASSOC_CONTAINS,
QName.createQName(NamespaceService.CONTENT_MODEL_1_0_URI, name),
ContentModel.TYPE_FOLDER,
contentProps).getChildRef();
nodeService.addAspect(parent,ContentModel.ASPECT_VERSIONABLE, null);
// create first CHILD node
NodeRef firstChild = nodeService.createNode(parent,
QName.createQName(NamespaceService.CONTENT_MODEL_1_0_URI, parent.getId()),
ContentModel.TYPE_CONTENT).getChildRef();
nodeService.addAspect(firstChild,ContentModel.ASPECT_VERSIONABLE, null);
Map<String, Serializable> versionProps = new HashMap<String, Serializable>();
//create the first version
versionProps.put("NomeVersione", "prima");
versionService.createVersion(parent, versionProps, false);
//create second CHILD node
NodeRef secondChild = nodeService.createNode(parent,
nodeService.addAspect(secondChild,ContentModel.ASPECT_VERSIONABLE, null);
//crea the second version
versionProps.put("NomeVersione", "seconda");
// END OF ADD OPERATIONS
nodeService.removeChild(parent, firstChild);
After the end of add operations, I want to remove a particular node (the one called "firstChild"). It happens, but this deletion occurs even in all previous versions! But the remove should happen only on the "live" SpaceStore and not on the "frozen" VersionStore.How can I leave unaltered the first and second version?Can anybody help me?Many thanks!Alessandro
