I am following the guide in the book Alfresco Developer Guide but have encountered a something I don't understand.In chapter 4, Digging into the developer class the book refers to org.alfresco.repo.content.metadata.PdfBoxMetadataExtracter class
and describe the code below:PDDocumentInformation docInfo = pdf.getDocumentInformation(); putRawValue(KEY_AUTHOR, docInfo.getAuthor(), rawProperties); putRawValue(KEY_TITLE, docInfo.getTitle(), rawProperties); putRawValue(KEY_SUBJECT, docInfo.getSubject(), rawProperties); Calendar created = docInfo.getCreationDate(); if (created != null) { putRawValue(KEY_CREATED, created.getTime(), rawProperties); }The problem is i looked in the code in:SDK AlfrescoEmbedded/source/alfresco-repository-3.4.d.jar/org.alfresco.repo.content.metadata.PdfBoxMetadataExtracter class
which contains the following code:* Copyright (C) 2005 Jesper Steen M√∏ller
* This file is part of Alfresco
* Alfresco is free software: you can redistribute it and/or modify
* it under the terms of the GNU Lesser General Public License as published by
* the Free Software Foundation, either version 3 of the License, or
* (at your option) any later version.
* Alfresco is distributed in the hope that it will be useful,
* but WITHOUT ANY WARRANTY; without even the implied warranty of
* MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
* GNU Lesser General Public License for more details.
* You should have received a copy of the GNU Lesser General Public License
* along with Alfresco. If not, see <http://www.gnu.org/licenses/>.
package org.alfresco.repo.content.metadata;
import java.util.ArrayList;
import org.alfresco.repo.content.MimetypeMap;
import org.apache.commons.logging.Log;
import org.apache.commons.logging.LogFactory;
import org.apache.tika.parser.Parser;
import org.apache.tika.parser.pdf.PDFParser;
* Metadata extractor for the PDF documents.
* <pre>
* <b>author:</b> – cm:author
* <b>title:</b> – cm:title
* <b>subject:</b> – cm:description
* <b>created:</b> – cm:created
* <b>(custom metadata):</b> –
* </pre>
* Uses Apache Tika
* @author Jesper Steen M√∏ller
* @author Derek Hulley
public class PdfBoxMetadataExtracter extends TikaPoweredMetadataExtracter
protected static Log pdfLogger = LogFactory.getLog(PdfBoxMetadataExtracter.class);
public static ArrayList<String> SUPPORTED_MIMETYPES = buildSupportedMimetypes(
new String[] { MimetypeMap.MIMETYPE_PDF },
new PDFParser()
public PdfBoxMetadataExtracter()
super(SUPPORTED_MIMETYPES);
@Override
protected Parser getParser() {
return new PDFParser();
I'm puzzled as I was expeting to see the code: DDocumentInformation docInfo = pdf.g …
