Hi:
I have followed the wiki to install Alfresco SDK 3.4 on Windows. I have imported the sample projects into Eclipsem but when I run the FirstFoundationClient.java, I get the next output:
Exception in thread "main" org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'RepoServerMgmt' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionService' while setting bean property 'transactionService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionService' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionManager' while setting bean property 'transactionManager'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1305)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1067)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:511)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:139)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:93)
at org.alfresco.util.BaseApplicationContextHelper.getApplicationContext(BaseApplicationContextHelper.java:67)
at org.alfresco.util.ApplicationContextHelper.getApplicationContext(ApplicationContextHelper.java:46)
at org.alfresco.sample.FirstFoundationClient.main(FirstFoundationClient.java:63)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionService' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionManager' while setting bean property 'transactionManager'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
… 17 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
… 27 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1401)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:512)
… 37 more
Caused by: org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.hibernate.dialect.DialectFactory.determineDialect(DialectFactory.java:59)
at org.hibernate.dialect.DialectFactory.buildDialect(DialectFactory.java:39)
at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:426)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:128)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2073)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1298)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:855)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:774)
at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1460)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1398)
… 44 more
I get the same output always…
Any idea or advise?
