Hi thereI'm having some problems building the source code of Alfresco.I copied it via svn from http://svn.alfresco.com/repos/alfresco-open-mirror/alfresco/HEAD.the command ant build-tomcat returns:Buildfile: /usr/local/alfresco/HEAD/root/build.xml
init:
[echo] user.home = /home/me
[echo] version.number = 4.0.d
BUILD FAILED
/usr/local/alfresco/HEAD/root/build.xml:146: Unable to create javax script engine for javascript
Total time: 1 second
java version:java version "1.6.0_22"
OpenJDK Runtime Environment (IcedTea6 1.10.2) (Gentoo build 1.6.0_22-b22)
OpenJDK Client VM (build 20.0-b11, mixed mode)
ant version:Apache Ant version 1.8.2 compiled on December 20 2010
env variables:export CATALINA_HOME=/usr/local/tomcat/home
export JAVA_OPTS="-Xmx1024m -XX:MaxPermSize=256m"
export TOMCAT_HOME=/usr/local/tomcat/home
export APP_TOMCAT_HOME=/usr/local/tomcat/home
Any ideas?Thank you in advance
