Hi all,I have a problem with a dashlet 3.4d with Alfresco Share. I have followed many tutorials but I can not solve my problem. Let me explain.I created Alfresco webscripts makes me a search for all documents that have a certain aspect. and return a json and it works if I access the page http://localhost:8080/alfresco/service/let/modelli visualize the result in json format.
{"modelli" : [
{"name" : "consulente.xls",
"link" : "\/alfresco\/d\/d\/workspace\/SpacesStore\/b632375f-e6a1-40e2-a2ee-dd858a4f8dc2\/consulente.xls",
Now I have created a dashlet of Alfresco Share, which should see the list of documents that have a certain aspect.Post the code for clarity:- getmodel.get.desc.xml<webscript>
<shortname>Crea da modello</shortname>
<description>Nuovo documento da modello esistente</description>
<!– one of dashlet, site-dashlet or user-dashlet –>
<family>dashlet</family>
<url>/components/dashlets/getmodel</url>
</webscript>
- getmodel.get.html.ftl<div class="dashlet">
<div class="title">Nuovo documento da modello esistente</div>
<div class="body scrollableList">
<div class="detail-list-item first-item last-item">
<h5>Modelli di documento</h5>
<table>
<#list modelli as mod>
<tr>
<td><b>Name</b></td><td>${mod.name}</td>
</tr>
<tr>
<td><b>Link</b></td><td><a href="${url.context}${mod.link}?guest=true">${url.context}${mod.link}</a></td>
</tr>
</#list>
</table>
</div>
</div>
</div>- getmodel.get.js
var connector = remote.connect("alfresco");
var data = connector.call("let/modelli");
if (data.status == 200) {
var result = eval('(' + data + ')');
model.modelli = result["modelli"];
}else{
model.modelli="zzzz";
And this is exception in tomcat log.Exception: freemarker.template.TemplateException - Expected collection or sequence. modelli evaluated instead to freemarker.template.SimpleScalar on line 7, column 32 in org/alfresco/components/dashlets/getmodel.get.html.ftl.
I understand that the problem are in the ftl template file but I can not figure out how I can fix and what is wrong. Help me to understand?Thank you all for the availability.
