Hi,I just installed alfresco 3.4.c and at the time I started the tomcat server I had this problem and the server is stopped.Any idea about the problem?10:58:40,240 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
10:58:40,245 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
10:58:40,247 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from file [C:\Alfresco\tomcat\webapps\alfresco\WEB-INF\classes\alfresco\module\org_alfresco_module_dod5015\alfresco-global.properties]
10:58:40,250 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from file [C:\Alfresco\tomcat\webapps\alfresco\WEB-INF\classes\alfresco\module\org_alfresco_module_wcmquickstart\alfresco-global.properties]
10:58:40,253 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from file [C:\Alfresco\tomcat\webapps\alfresco\WEB-INF\classes\alfresco\module\test\alfresco-global.properties]
10:58:40,255 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from file [C:\Alfresco\tomcat\webapps\alfresco\WEB-INF\classes\alfresco\module\tests\alfresco-global.properties]
10:58:40,257 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/C:/Alfresco/tomcat/shared/classes/alfresco-global.properties]
10:58:40,374 INFO [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
10:58:40,523 INFO [org.alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/version.properties]
10:58:40,560 INFO [org.alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/domain/cache-strategies.properties]
10:58:40,617 INFO [org.alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/module/org.alfresco.module.vti/context/vti.properties]
10:58:40,620 INFO [org.alfresco.config.FixedPropertyPlaceholderConfigurer] Loading properties file from URL [file:/C:/Alfresco/tomcat/shared/classes/alfresco/extension/custom-vti.properties]
10:58:48,326 WARN [org.hibernate.cfg.SettingsFactory] Could not obtain connection metadata
org.apache.commons.dbcp.SQLNestedException: Cannot create PoolableConnectionFactory (Communications link failure
The last packet sent successfully to the server was 0 milliseconds ago. The driver has not received any packets from the server.)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1225)
at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:81)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:84)
at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2073)
at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1298)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:855)
at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:774)
at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:211)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1460)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1398)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:512)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1305)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1067)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:511)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:261)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:192)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:905)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:740)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:500)
Caused by: com.mysql.jdbc.exceptions.jdbc4.CommunicationsException: Communications link failure
at com.mysql.jdbc.Util.handleNewInstance(Util.java:409)
at com.mysql.jdbc.SQLError.createCommunicationsException(SQLError.java:1118)
at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:343)
at com.mysql.jdbc.ConnectionImpl.connectOneTryOnly(ConnectionImpl.java:2308)
at com.mysql.jdbc.ConnectionImpl.createNewIO(ConnectionImpl.java:2122)
at com.mysql.jdbc.ConnectionImpl.<init>(ConnectionImpl.java:774)
at com.mysql.jdbc.JDBC4Connection.<init>(JDBC4Connection.java:49)
at com.mysql.jdbc.ConnectionImpl.getInstance(ConnectionImpl.java:375)
at com.mysql.jdbc.NonRegisteringDriver.connect(NonRegisteringDriver.java:289)
at org.apache.commons.dbcp.DriverConnectionFactory.createConnection(DriverConnectionFactory.java:38)
at org.apache.commons.dbcp.PoolableConnectionFactory.makeObject(PoolableConnectionFactory.java:294)
at org.apache.commons.dbcp.BasicDataSource.validateConnectionFactory(BasicDataSource.java:1247)
at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1221)
… 77 more
Caused by: java.net.ConnectException: Connection refused: connect
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:366)
at java.net.Socket.connect(Socket.java:525)
at java.net.Socket.connect(Socket.java:475)
at java.net.Socket.<init>(Socket.java:372)
at java.net.Socket.<init>(Socket.java:215)
at com.mysql.jdbc.StandardSocketFactory.connect(StandardSocketFactory.java:256)
at com.mysql.jdbc.MysqlIO.<init>(MysqlIO.java:292)
… 92 more
10:58:48,415 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'RepoServerMgmt' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionService' while setting bean property 'transactionService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionService' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionManager' while setting bean property 'transactionManager'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:328)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionService' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'transactionManager' while setting bean property 'transactionManager'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
… 40 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'transactionManager' defined in class path resource [alfresco/hibernate-context.xml]: Cannot resolve reference to bean 'sessionFactory' while setting bean property 'sessionFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
… 50 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'sessionFactory' defined in class path resource [alfresco/hibernate-context.xml]: Invocation of init method failed; nested exception is org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1401)
… 60 more
Caused by: org.hibernate.HibernateException: Hibernate Dialect must be explicitly set
at org.hibernate.dialect.DialectFactory.determineDialect(DialectFactory.java:59)
at org.hibernate.dialect.DialectFactory.buildDialect(DialectFactory.java:39)
at org.hibernate.cfg.SettingsFactory.determineDialect(SettingsFactory.java:426)
at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:128)
… 67 more
