Hi team, from the last few days i'm facing a problem with configuring the mysql with alfresco.Environment:OS: windows XP professional editionAlfresco: 3.0 labs stable versionMy SQL: mysql-essential-5.0.18-win32what i have done is, i installed My SQL sucessfully in my local machine.custom-repository.properties
db.driver=org.gjt.mm.mysql.Driver
#db.driver=com.mysql.jdbc.Driver
db.url=jdbc:mysql://localhost:3306/alfresco
i kept mysql-connector-java-5.1.6-bin.jar as it is in tomcat/lib.and even tried db.driver=com.mysql.jdbc.Driver and db.url=jdbc:mysql://localhost:3306/alfresco in custom-repository.properties.custom-hibernate-dialect.properties#
# MySQL dialect (default)
hibernate.dialect=org.hibernate.dialect.MySQLInnoDBDialect
#hibernate.dialect=org.hibernate.dialect.MySQLDialect
even i tried with hibernate.dialect=org.hibernate.dialect.MySQLDialectNOTE: even i tired this jar mysql-connector-java-3.1.6-bin.jar and removed the existing jar and viceversa and i intslled alfresco and mysql in C:\ drive and still there is 3 gb free space avaiable in this drive.But still no luck. any compatible issues.15:28:16,493 INFO [config.xml.XMLConfigService$PropertyConfigurer] Loading pro
perties file from class path resource [alfresco/file-servers.properties]
15:28:50,551 INFO [domain.schema.SchemaBootstrap] Schema managed by database d
ialect org.hibernate.dialect.MySQLInnoDBDialect.
15:28:56,443 ERROR [domain.schema.SchemaBootstrap] Schema auto-update failed
org.hibernate.exception.GenericJDBCException: could not get table metadata: alf_
audit_fact
at org.hibernate.exception.SQLStateConverter.handledNonSpecificException
(SQLStateConverter.java:103)
at org.hibernate.exception.SQLStateConverter.convert(SQLStateConverter.j
ava:91)
at org.hibernate.exception.JDBCExceptionHelper.convert(JDBCExceptionHelp
er.java:43)
er.java:29)
at org.hibernate.tool.hbm2ddl.DatabaseMetadata.getTableMetadata(Database
Metadata.java:105)
at org.hibernate.cfg.Configuration.generateSchemaUpdateScript(Configurat
ion.java:954)
at org.alfresco.repo.domain.schema.SchemaBootstrap.updateSchema(SchemaBo
otstrap.java:649)
at org.alfresco.repo.domain.schema.SchemaBootstrap.onBootstrap(SchemaBoo
tstrap.java:1123)
at org.alfresco.util.AbstractLifecycleBean.onApplicationEvent(AbstractLi
fecycleBean.java:62)
at org.springframework.context.event.SimpleApplicationEventMulticaster$1
.run(SimpleApplicationEventMulticaster.java:77)
at org.springframework.core.task.SyncTaskExecutor.execute(SyncTaskExecut
or.java:49)
at org.springframework.context.event.SimpleApplicationEventMulticaster.m
ulticastEvent(SimpleApplicationEventMulticaster.java:75)
at org.springframework.context.support.AbstractApplicationContext.publis
hEvent(AbstractApplicationContext.java:246)
at org.springframework.context.support.AbstractApplicationContext.refres
h(AbstractApplicationContext.java:355)
at org.springframework.web.context.ContextLoader.createWebApplicationCon
text(ContextLoader.java:244)
at org.springframework.web.context.ContextLoader.initWebApplicationConte
xt(ContextLoader.java:187)
at org.springframework.web.context.ContextLoaderListener.contextInitiali
zed(ContextLoaderListener.java:49)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContex
t.java:3843)
at org.apache.catalina.core.StandardContext.start(StandardContext.java:4
342)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase
.java:791)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:77
1)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:830)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:719
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:490
at org.apache.catalina.startup.HostConfig.lifecycleEvent(HostConfig.java
:311)
at org.apache.catalina.util.LifecycleSupport.fireLifecycleEvent(Lifecycl
eSupport.java:117)
at org.apache.catalina.core.StandardEngine.start(StandardEngine.java:443
at org.apache.catalina.core.StandardService.start(StandardService.java:5
16)
at org.apache.catalina.core.StandardServer.start(StandardServer.java:710
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
Caused by: java.sql.SQLException: Can't create/write to file 'C:\WINDOWS\TEMP\#s
ql_f0c_0.MYD' (Errcode: 17)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:2851)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1534)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:1625)
at com.mysql.jdbc.Connection.execSQL(Connection.java:2291)
at com.mysql.jdbc.Connection.execSQL(Connection.java:2226)
at com.mysql.jdbc.Statement.executeQuery(Statement.java:1159)
at com.mysql.jdbc.DatabaseMetaData.getColumns(DatabaseMetaData.java:890)
at org.hibernate.tool.hbm2ddl.TableMetadata.initColumns(TableMetadata.ja
va:146)
at org.hibernate.tool.hbm2ddl.TableMetadata.<init>(TableMetadata.java:32
Metadata.java:90)
… 36 more
15:28:56,459 ERROR [web.context.ContextLoader] Context initialization failed
org.alfresco.error.AlfrescoRuntimeException: Schema auto-update failed
tstrap.java:1192)
or.java:49)
t.java:3843)
342)
.java:791)
1)
:311)
eSupport.java:117)
16)
java:39)
sorImpl.java:25)
Caused by: org.hibernate.exception.GenericJDBCException: could not get table met
adata: alf_audit_fact
ava:91)
er.java:43)
er.java:29)
Metadata.java:105)
ion.java:954)
otstrap.java:649)
tstrap.java:1123)
… 33 more
any help is appriciated.
