I am following a tutorial for Alfresco, called Alfresco_3_Enterprise_Content_Management_ImplementationAt a certain point, testing the aspects, it tells me to change the file custom-model-context.xml.sampleinto custom-model-context.xmlThen it tells me to edit the file customModel.xmlwith
<aspects>
<!– Definition of new Content Aspect: Customer Details –>
<aspect name="custom:CustomerDetails">
<title>Customer Details</title>
<properties>
<property name="custom:CustomerName">
<title>Customer Name</title>
<type>d:text</type>
<protected>false</protected>
<mandatory>false</mandatory>
<multiple>false</multiple>
</property>
<property name="custom:CustomerContactName">
<title>Customer Contact Name</title>
<type>d:text</type>
</property>
<property name="custom:CustomerContactPhone">
<title>Customer Contact Phone</title>
<type>d:text</type>
</property>
<property name="custom:CustomerProjectID">
<title>Customer Project ID</title>
<type>d:int</type>
</property>
<property name="custom:NewCustomer">
<title>New Customer</title>
<type>d:boolean</type>
<default>true</default>
</property>
</properties>
</aspect>
</aspects>
right before the line </model>last, it indicates to edit the fileweb-client-config-custom.xml with<!– Lists the custom aspect in business rules Action wizard –><config evaluator="string-compare" condition="Action Wizards"> <aspects> <aspect name="custom:CustomerDetails"/> </aspects></config> <!– Displays the properties in view details page –> <config evaluator="aspect-name" condition="custom:CustomerDetails"> <property-sheet> <separator name="sepCust1" display-label="Customer Details"component-generator="HeaderSeparatorGenerator" /> <show-property name="custom:CustomerName"/> <show-property name="custom:CustomerContactName"/> <show-property name="custom:CustomerContactPhone"/> <show-property name="custom:CustomerProjectID"/> <show-property name="custom:NewCustomer"/> </property-sheet> </config>This is the error that the file alfresco.log indicates
rg.springframework.beans.factory.BeanCreationException: Error creating bean with name 'extension.dictionaryBootstrap' defined in file [/opt/Alfresco/tomcat/shared/classes/alfresco/extension/custom-model-context.xml]: Invocation of init method failed; nested exception is org.alfresco.service.cmr.dictionary.DictionaryException: 10300001 Could not import bootstrap model alfresco/extension/customModel.xml
Caused by: org.alfresco.service.cmr.dictionary.DictionaryException: 10300001 Could not import bootstrap model alfresco/extension/customModel.xml
at org.alfresco.repo.dictionary.DictionaryBootstrap.onDictionaryInit(DictionaryBootstrap.java:151)
at org.alfresco.repo.dictionary.DictionaryBootstrap.bootstrap(DictionaryBootstrap.java:108)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeCustomInitMethod(AbstractAutowireCapableBeanFactory.java:1242)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1208)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1172)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:427)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:249)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:155)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:246)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:160)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:291)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:352)
Caused by: org.alfresco.service.cmr.dictionary.DictionaryException: 10300000 Failed to parse model
at org.alfresco.repo.dictionary.M2Model.createModel(M2Model.java:99)
at org.alfresco.repo.dictionary.DictionaryBootstrap.onDictionaryInit(DictionaryBootstrap.java:146)
… 43 more
Caused by: org.jibx.runtime.JiBXException: Expected "{http://www.alfresco.org/model/dictionary/1.0}model" end tag, found "{http://www.alfresco.org/model/dictionary/1.0}aspects" start tag (line 35, col 10)
at org.jibx.runtime.impl.UnmarshallingContext.parsePastCurrentEndTag(UnmarshallingContext.java:800)
at org.alfresco.repo.dictionary.JiBX_root_projects_repository_source_java_org_alfresco_repo_dictionary_m2bindingM2Model_access.unmarshal()
at org.jibx.runtime.impl.UnmarshallingContext.unmarshalElement(UnmarshallingContext.java:2773)
at org.jibx.runtime.impl.UnmarshallingContext.unmarshalDocument(UnmarshallingContext.java:2916)
at org.alfresco.repo.dictionary.M2Model.createModel(M2Model.java:94)
… 44 moreIf I pass on to edit the custom model context xml file, it allows alfresco to run (it crashes otherwise) and inside I can see the aspect named customerdetail. Any attempt to apply it to a file however, show a system error.
