We have a problem while trying to authenticate our CIFS users with Kerberos/JAAS.Context :- alfresco-community-tomcat-1.3.0- linux Debian/Sarge- Java 1.5.0_05From a fresh alfresco install, I added these 2 files :- tomcat/shared/classes/alfresco/extension/jaas-authentication-context.xml<?xml version='1.0' encoding='UTF-8'?>
<beans>
<!– The authentication component. –>
<!– Jass authentication - most of the config goes somewhere else –>
<bean id="authenticationComponentImpl"
class="org.alfresco.repo.security.authentication.jaas.JAASAuthenticationComponent">
<property name="realm">
<value>MYDOMAIN.PRIV</value>
</property>
<property name="jaasConfigEntryName">
<value>Alfresco</value>
</property>
</bean>
<bean id="alfDaoImpl" class="org.springframework.transaction.interceptor.TransactionProxyFactoryBean">
<property name="proxyInterfaces">
<value>
org.alfresco.repo.security.authentication.MutableAuthenticationDao
</value>
</property>
<property name="transactionManager">
<ref bean="transactionManager" />
</property>
<property name="target">
<bean class="org.alfresco.repo.security.authentication.ntlm.NullMutableAuthenticationDao" />
</property>
<property name="transactionAttributes">
<props>
<prop key="*">${server.transaction.mode.default}</prop>
</props>
</property>
</bean>
</beans>- tomcat/shared/classes/alfresco/extension/file-servers-custom.xml<alfresco-config area="file-servers">
<config evaluator="string-compare" condition="CIFS Server">
<host name="${localname}_A" domain="MYDOMAIN"/>
</config>
<authenticator type="enterprise">
<KDC>kdcserver.mydomain.priv</KDC>
<Realm>MYDOMAIN.PRIV</Realm>
<Password>mypassword</Password>
</authenticator>
</config>
</alfresco-config>The Kerberos server is up and running. I could add some user and authenticate with them in the web interface. I added a special user "cifs/ged2_a" (ged2 is the server name where alfresco is installed). In the Kerberos logfile, I could see that this user is used when alfresco is started.All authentication works (web client, ftp, web dave), but CIFS fails.log when trying to log in from a Windows box :15:37:29,428 DEBUG [alfresco.smb.protocol] TCP-SMB session request received from 192.168.1.65
15:37:29,439 DEBUG [alfresco.smb.protocol] Waiting for TCP-SMB session request …
15:37:29,439 DEBUG [alfresco.smb.protocol] Server session started
15:37:29,441 DEBUG [alfresco.smb.protocol] Negotiated SMB dialect - NT LM 0.12
15:37:29,488 DEBUG [alfresco.smb.protocol] Assigned protocol handler - org.alfresco.filesys.smb.server.NTProtocolHandler
15:37:29,491 DEBUG [smb.protocol.auth] NT Session setup SPNEGO, MID=1488, UID=0, PID=65279
15:37:29,590 DEBUG [smb.protocol.auth] User logged on (type Normal)
15:37:29,592 DEBUG [smb.protocol.auth] NT Session setup SPNEGO, MID=1496, UID=0, PID=65279
15:37:29,596 WARN [smb.protocol.auth] Authentication component does not support MD4 password hashes
log when trying to log in with smbclient :smbclient //ged2/Alfresco -k
I must use 'ged2' instead of 'ged2_a', because smbclient is unable to resolv ged2_a address.11:37:45,609 DEBUG [alfresco.smb.protocol] TCP-SMB session request received from 192.168.1.206
11:37:45,609 DEBUG [alfresco.smb.protocol] Waiting for TCP-SMB session request …
11:37:45,609 DEBUG [alfresco.smb.protocol] Server session started
11:37:45,621 DEBUG [alfresco.smb.protocol] Negotiated SMB dialect - NT LM 0.12
11:37:45,621 DEBUG [alfresco.smb.protocol] Assigned protocol handler - org.alfresco.filesys.smb.server.NTProtocolHandler
11:37:45,625 DEBUG [smb.protocol.auth] NT Session setup SPNEGO, MID=2, UID=0, PID=2876
GSSException: No valid credentials provided
No valid credentials provided (Mechanism level: Failed to find any Kerberos Key)
11:37:45,656 ERROR [alfresco.smb.protocol] Closing session due to exception
at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.doSpnegoSessionSetup(EnterpriseCifsAuthenticator.java:1054)
at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.processSessionSetup(EnterpriseCifsAuthenticator.java:624)
at org.alfresco.filesys.smb.server.NTProtocolHandler.procSessionSetup(NTProtocolHandler.java:399)
at org.alfresco.filesys.smb.server.NTProtocolHandler.runProtocol(NTProtocolHandler.java:213)
at org.alfresco.filesys.smb.server.SMBSrvSession.run(SMBSrvSession.java:1554)
Is it possible to configure CIFS to use Kerberos without using NTLM and Active Directory ? Is there something special to configure on the Kerberos server and client ?Do you have any hint ? This is the only issue we encounter on this project.
