Hi @all,we have a big problem with our Alfresco installation, because after the Migration from 3.2r2 to the new edition 3.3 our repository will not be able to start with the new version.The old version was running on Ubuntu 9.04 and the new version should run on Windows Server 2003. The installation was no problem, but the restore from the alf_data and mysql. What we had do is, we uncomment the index.recorvery.mod to AUTO. And now that is the output from the Log file.08:56:20,995 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
08:56:20,996 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
08:56:20,996 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/opt/alfresco32/tomcat/shared/classes/alfresco-global.properties]
08:56:21,129 INFO [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
08:56:33,797 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexRecoveryBootstrap' defined in class path resource [alfresco/bootstrap-context.xml]: Cannot resolve reference to bean 'indexRecoveryComponent' while setting bean property 'indexRecoveryComponent'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexRecoveryComponent' defined in class path resource [alfresco/index-recovery-context.xml]: Error setting property values; nested exception is org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessExceptions (1) are:
PropertyAccessException 1: org.springframework.beans.MethodInvocationException: Property 'recoveryMode' threw exception; nested exception is java.lang.IllegalArgumentException: No enum const class org.alfresco.repo.node.index.FullIndexRecoveryComponent$RecoveryMode.Auto
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexRecoveryComponent' defined in class path resource [alfresco/index-recovery-context.xml]: Error setting property values; nested exception is org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessExceptions (1) are:
Caused by: org.springframework.beans.PropertyBatchUpdateException; nested PropertyAccessException details (1) are:
Caused by: java.lang.IllegalArgumentException: No enum const class org.alfresco.repo.node.index.FullIndexRecoveryComponent$RecoveryMode.Auto
at java.lang.Enum.valueOf(Enum.java:196)
at org.alfresco.repo.node.index.FullIndexRecoveryComponent$RecoveryMode.valueOf(FullIndexRecoveryComponent.java:69)
at org.alfresco.repo.node.index.FullIndexRecoveryComponent.setRecoveryMode(FullIndexRecoveryComponent.java:121)
at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:821)
at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:645)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:78)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:59)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1127)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:862)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:423)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:249)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:155)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:246)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:160)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:267)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:110)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1100)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeansOfType(DefaultListableBeanFactory.java:248)
at org.springframework.context.support.AbstractApplicationContext.getBeansOfType(AbstractApplicationContext.java:820)
at org.springframework.context.support.AbstractApplicationContext.registerListeners(AbstractApplicationContext.java:597)
08:56:39,077 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
08:56:39,537 INFO [org.alfresco.config.JBossEnabledWebApplicationContext] Refreshing org.alfresco.config.JBossEnabledWebApplicationContext@87080f: display name [Root WebApplicationContext]; startup date [Fri Jun 11 08:56:39 CEST 2010]; root of context hierarchy
08:56:40,132 INFO [org.alfresco.config.JBossEnabledWebApplicationContext] Bean factory for application context [org.alfresco.config.JBossEnabledWebApplicationContext@87080f]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1cad3a6
08:56:41,544 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 22 Web Scripts (+0 failed), 24 URLs
08:56:41,553 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 156.79488ms)
08:56:41,636 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 40 Web Scripts (+0 failed), 42 URLs
08:56:41,665 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 101.59984ms)
08:56:41,723 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
We need the data from the repository, and I don't know how we can restore the data from the alf_data and mysql database.Can anybody help us to find a way, to bring up running alfresco or recovery the data.
