HI all,
i have created a inbound rule which "executes a script" when items are imported to a space, the script file contains the following:
document.name=document.properties["sys:node-dbid"] + "_" + document.name;
now what happens is whenever i import a ".txt" file in to the space, "db-id" is appended along with the name,
for example the name changes to "3241_abc.txt" when i import "abc.txt" to the space.
but the problem is when i import ".jpg" or ".doc" in to the space "db-id" is not appended along with the name.
for example when i import "nature.jpg" to the space the name is not changed which is supposed to change like "3255_nature.jpg"
dont know wats the problem…
any help??
