Alfresco's FTP server per default uses UTF8 on its control channel. Most FTP client's do not (I even had to hack Apache Common-VFS to handle this). So instead of fighting with all clients, I wanted to convince Alfresco 3.2r to use ISO-8859-1. So I created:C:\Alfresco\tomcat\shared\classes\alfresco\extension\subsystems\fileServers\default\default\custom-file-servers-context.xmlAs per documentation:http://wiki.alfresco.com/wiki/File_Server_Subsystem#Advanced_Spring_Overrides_2Containing:<?xml version="1.0" encoding="UTF-8"?>
<!DOCTYPE beans PUBLIC "-//SPRING/DTD BEAN//EN"
"http://www.springframework.org/dtd/spring-beans.dtd">
<beans>
<bean id="ftpServerConfig" class="org.alfresco.filesys.config.FTPConfigBean">
<property name="charSet">
<value>ISO-8859-1</value>
</property>
</bean>
</beans>
But that breaks the FTP service. I also found an example custom-file-servers-context.xml containing all kind of beans (sniplet below) and used a modified version of that.
<bean id="fileServerConfiguration" class="org.alfresco.filesys.config.ServerConfigurationBean" parent="fileServerConfigurationBase">
<property name="cifsConfigBean">
<ref bean="cifsServerConfig" />
</property>
<property name="ftpConfigBean">
<ref bean="ftpServerConfig" />
</property>
<property name="nfsConfigBean">
<ref bean="nfsServerConfig" />
</property>
<property name="filesystemContexts">
<ref bean="filesystemContexts" />
</property>
<property name="securityConfigBean">
<ref bean="fileSecurityConfig" />
</property>
</bean>
<property name="serverEnabled">
<value>${ftp.enabled}</value>
</property>
<property name="port">
<value>${ftp.port}</value>
</property>
</property>
<!– IPv6 support –>
<property name="ipv6Enabled">
<value>${ftp.ipv6.enabled}</value>
</property>
<!– FTP authentication –>
<property name="authenticator">
<ref bean="FtpAuthenticator" />
</property>
<!– FTP server debug settings –>
<!– Enable 'log4j.logger.org.alfresco.fileserver=debug' in log4j.properties file –>
<property name="debugFlags"> <value>File,Search,Error,Directory,Info,DataPort</value> </property>
</bean>
The FTP service is up, but still running UTF8.What am I doing wrong?
