Hi there,I'm trying to develop a java-backed web script to load a file from the file-system into the alfresco repository, the file was created into the repository but the content, content-type and Encoding, doesn't write, when I try to access with the webclient I get the message:The node's content is missing: node: workspace://SpacesStore/e8755d53-54f7-445c-bb47-95e431612f46 reader: null Please contact your system administrator.This is because the content doesn't write, the alfresco version is:alfresco-community-tomcat-3.3g with mysql 5.Also, when the script run for first time, alfresco is deployed again and generate this error message:
Cannot create JDBC driver of class '' for connect URL 'null'
java.sql.SQLException: No suitable driver
at java.sql.DriverManager.getDriver(DriverManager.java:264)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:1143)
at org.apache.tomcat.dbcp.dbcp.BasicDataSource.getConnection(BasicDataSource.java:880)
at org.alfresco.config.JndiObjectFactoryBean.lookup(JndiObjectFactoryBean.java:44)
at org.springframework.jndi.JndiObjectFactoryBean.lookupWithFallback(JndiObjectFactoryBean.java:201)
at org.springframework.jndi.JndiObjectFactoryBean.afterPropertiesSet(JndiObjectFactoryBean.java:187)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1460)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1398)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:512)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:322)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:106)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1305)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1067)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:511)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:261)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:192)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:637)
at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:563)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498)
at org.apache.catalina.startup.Ho18:45:59,926 User:admin INFO [domain.schema.SchemaBootstrap] Esquema gestionado por el gestor de base de datos org.hibernate.dialect.MySQLInnoDBDialect.
18:46:01,087 User:admin INFO [domain.schema.SchemaBootstrap] No se hicieron cambios en el esquema.
Successive executions of the script runs without any error message.The code is:
package org.alfresco.cde;
import java.io.IOException;
import java.io.Serializable;
import java.util.HashMap;
import java.util.Map;
import javax.servlet.http.HttpServletResponse;
import org.alfresco.model.ContentModel;
import org.alfresco.repo.content.MimetypeMap;
import org.alfresco.repo.security.authentication.AuthenticationUtil;
import org.alfresco.repo.security.authentication.AuthenticationUtil.RunAsWork;
import org.alfresco.service.ServiceRegistry;
import org.alfresco.service.cmr.repository.NodeRef;
import org.alfresco.service.cmr.repository.ChildAssociationRef;
import org.alfresco.service.cmr.repository.ContentService;
import org.alfresco.service.cmr.repository.ContentWriter;
import org.alfresco.service.cmr.repository.NodeService;
import org.alfresco.service.cmr.repository.StoreRef;
import org.alfresco.service.cmr.search.ResultSet;
import org.alfresco.service.cmr.search.SearchService;
import org.alfresco.service.namespace.NamespaceService;
import org.alfresco.service.namespace.QName;
import org.alfresco.util.ApplicationContextHelper;
import org.springframework.context.ApplicationContext;
import org.springframework.extensions.webscripts.WebScriptException;
import org.springframework.extensions.webscripts.WebScriptRequest;
import org.springframework.extensions.webscripts.WebScriptResponse;
import org.springframework.extensions.webscripts.AbstractWebScript;
public class LotusIntegator extends AbstractWebScript {
protected ServiceRegistry services;
WebScriptRequest request;
public void execute(WebScriptRequest req, WebScriptResponse res)
throws IOException
ApplicationContext ctx = ApplicationContextHelper.getApplicationContext();
final ServiceRegistry serviceRegistry = (ServiceRegistry) ctx.getBean(ServiceRegistry.SERVICE_REGISTRY);
request = req;
try
AuthenticationUtil.runAs(new RunAsWork<String>() {
@SuppressWarnings("synthetic-access")
public String doWork() throws Exception {
String descripcion = request.getParameter("desc");
String titulo = request.getParameter("title");
String nombre = request.getParameter("name");
ContentService contentService = serviceRegistry.getContentService();
SearchService searchService = serviceRegistry.getSearchService();
NodeService nodeService = serviceRegistry.getNodeService();
StoreRef storeRef = new StoreRef(StoreRef.PROTOCOL_WORKSPACE, "SpacesStore");
ResultSet resultSet = searchService.query(storeRef, SearchService.LANGUAGE_LUCENE, "PATH:\"/app:company_home\"");
NodeRef companyHome = resultSet.getNodeRef(0);
resultSet.close();
Map<QName, Serializable> contentProps = new HashMap<QName, Serializable>();
contentProps.put(ContentModel.PROP_NAME, nombre);
ChildAssociationRef association = nodeService.createNode(companyHome,
ContentModel.ASSOC_CONTAINS,
QName.createQName(NamespaceService.CONTENT_MODEL_PREFIX, nombre),
ContentModel.TYPE_CONTENT,
contentProps);
NodeRef content = association.getChildRef();
// add titled aspect (for Web Client display)
Map<QName, Serializable> titledProps = new HashMap<QName, Serializable>();
titledProps.put(ContentModel.PROP_TITLE, titulo);
titledProps.put(ContentModel.PROP_DESCRIPTION, descripcion);
nodeService.addAspect(content, ContentModel.ASPECT_TITLED, titledProps);
ContentWriter writer = contentService.getWriter(content, ContentModel.PROP_CONTENT, true);
writer.setMimetype(MimetypeMap.MIMETYPE_TEXT_PLAIN);
writer.setEncoding("UTF-8");
writer.putContent("This is a Test…");
System.err.println("Writer Size: " + writer.getSize());
return "cool";
},"admin");
catch(Exception e)
throw new WebScriptException(HttpServletResponse.SC_NOT_FOUND, e.getMessage());
res.getWriter().write("Carga OK");
Thanks in advance for any suggestion.bye
