Hi, freinds
I'm learning the Alfresco web scripts api. I called the login api to get a alf_ticket string (TICKET_60af92a1ae009fd39fd121fc871eab9b966070c5). I appended this string to the url which calls the api getChilden. Everything's smoothly and I got the return results. But when I called the method which uses http POST method, for example the file upload api. The login dialog poped up.
Does any one know the authentication method used for the api in http POST method? I don't want the end user to see the login dialog.
Thanks in advance
