: : : [javac] symbol : method getLenientFormatters() [javac] location: class org.alfresco.util.CachingDateFormat [javac] for (SimpleDateFormat df : CachingDateFormat.getLenientFormatters()) [javac] ^ [javac] /alfresco/HEAD/root/projects/repository/source/java/org/alfresco/repo/search/impl/lucene/analysis/DateTimeTokenFilter.java:98: cannot find symbol [javac] symbol : method lenientParse(java.lang.String) [javac] location: class org.alfresco.util.CachingDateFormat [javac] date = CachingDateFormat.lenientParse(candidate.termText()); [javac] ^ [javac] /alfresco/HEAD/root/projects/repository/source/java/org/alfresco/repo/search/impl/lucene/analysis/DateTokenFilter.java:78: cannot find symbol [javac] symbol : method lenientParse(java.lang.String) [javac] location: class org.alfresco.util.CachingDateFormat [javac] date = CachingDateFormat.lenientParse(candidate.termText()); [javac] ^ [javac] Note: Some input files additionally use or override a deprecated API. [javac] Note: Some input files additionally use unchecked or unsafe operations. [javac] 6 errors [javac] 100 warnings BUILD FAILED /alfresco/HEAD/root/projects.xml:246: The following error occurred while executing this line: /alfresco/HEAD/root/macros.xml:27: Compile failed; see the compiler error output for details.
