I am new to Activiti. I am trying to design a Process with a Sub-process i.e call activity, within a main process. MainProcess(helloworldprocess.bpmn20.xml)<?xml version="1.0" encoding="UTF-8"?>
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/processdef">
<process id="helloworldprocess" name="helloworldprocess" isExecutable="true">
<startEvent id="Start" name="Start"></startEvent>
<serviceTask id="HelloWorld" name="HelloWorld" activiti:class="com.vega.activiti.HelloWorld"></serviceTask>
<sequenceFlow id="sid-6447475E-EFF3-4FCD-B743-6767B8340EAA" sourceRef="Start" targetRef="HelloWorld"></sequenceFlow>
<serviceTask id="MainProcess" name="MainProcess" activiti:async="true" activiti:class="com.vega.activiti.MainProcess"></serviceTask>
<endEvent id="End" name="End"></endEvent>
<sequenceFlow id="sid-8C35EFC3-12A4-4196-8929-9ABBA17AC282" sourceRef="MainProcess" targetRef="End"></sequenceFlow>
<callActivity id="helloworldSubProcess" name="helloworldSubProcess">
<extensionElements>
<activiti:in source="inputMsg" target="inputMsg"></activiti:in>
<activiti:in source="validateTrade" target="validateTrade"></activiti:in>
<activiti:out source="outputMsg" target="outputMsg"></activiti:out>
</extensionElements>
</callActivity>
<sequenceFlow id="sid-C501F40E-5E56-4B3E-9D3B-1BB13F2FD491" sourceRef="HelloWorld" targetRef="helloworldSubProcess"></sequenceFlow>
<sequenceFlow id="sid-12BA3BE5-C3CF-43A7-BD9B-BB616592582F" sourceRef="helloworldSubProcess" targetRef="MainProcess"></sequenceFlow>
</process>
</definitions>
SubProcess(helloworldSubProcess.bpmn20.xml)<?xml version="1.0" encoding="UTF-8"?>
<process id="helloworldSubProcess" name="helloworldSubProcess" isExecutable="true">
<startEvent id="SubprocessStart" name="SubprocessStart"></startEvent>
<sequenceFlow id="sid-D59762FE-598B-4D7F-BDCB-DADF495FB88E" sourceRef="SubprocessStart" targetRef="Subprocess1"></sequenceFlow>
<serviceTask id="Subprocess1" name="Subprocess1" activiti:class="com.vega.activiti.SubProcess1"></serviceTask>
<endEvent id="EndSubProcess" name="EndSubProcess"></endEvent>
<sequenceFlow id="sid-C7BFA9C8-1791-4F6D-A0B9-86B99EFFDDCE" sourceRef="Subprocess1" targetRef="EndSubProcess"></sequenceFlow>
</process>
</definitions>
My Main Process contains a Service Task followed by callactvity then followed by another Service task. Now when I run process the flow starts with first service task i.e HelloWorld Task then to the Subprocess. But when subprocess ends the process stops with Error:Exception in thread "main" org.activiti.engine.ActivitiObjectNotFoundException: no processes deployed with key 'null'
at org.activiti.engine.impl.persistence.deploy.DeploymentManager.findDeployedLatestProcessDefinitionByKey(DeploymentManager.java:125)
at org.activiti.engine.impl.bpmn.behavior.CallActivityBehavior.execute(CallActivityBehavior.java:80)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationActivityExecute.execute(AtomicOperationActivityExecute.java:60)
at org.activiti.engine.impl.interceptor.CommandContext.performOperation(CommandContext.java:97)
at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperationSync(ExecutionEntity.java:633)
at org.activiti.engine.impl.persistence.entity.ExecutionEntity.performOperation(ExecutionEntity.java:628)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerStart.eventNotificationsCompleted(AtomicOperationTransitionNotifyListenerStart.java:52)
at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:56)
at org.activiti.engine.impl.pvm.runtime.AbstractEventAtomicOperation.execute(AbstractEventAtomicOperation.java:49)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionCreateScope.execute(AtomicOperationTransitionCreateScope.java:49)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerTake.execute(AtomicOperationTransitionNotifyListenerTake.java:80)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionDestroyScope.execute(AtomicOperationTransitionDestroyScope.java:116)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationTransitionNotifyListenerEnd.eventNotificationsCompleted(AtomicOperationTransitionNotifyListenerEnd.java:35)
at org.activiti.engine.impl.persistence.entity.ExecutionEntity.take(ExecutionEntity.java:452)
at org.activiti.engine.impl.persistence.entity.ExecutionEntity.take(ExecutionEntity.java:430)
at org.activiti.engine.impl.bpmn.behavior.BpmnActivityBehavior.performOutgoingBehavior(BpmnActivityBehavior.java:140)
at org.activiti.engine.impl.bpmn.behavior.BpmnActivityBehavior.performDefaultOutgoingBehavior(BpmnActivityBehavior.java:66)
at org.activiti.engine.impl.bpmn.behavior.FlowNodeActivityBehavior.leave(FlowNodeActivityBehavior.java:44)
at org.activiti.engine.impl.bpmn.behavior.AbstractBpmnActivityBehavior.leave(AbstractBpmnActivityBehavior.java:47)
at org.activiti.engine.impl.bpmn.behavior.ServiceTaskJavaDelegateActivityBehavior.execute(ServiceTaskJavaDelegateActivityBehavior.java:41)
at org.activiti.engine.impl.bpmn.helper.ClassDelegate.execute(ClassDelegate.java:158)
at org.activiti.engine.impl.bpmn.behavior.FlowNodeActivityBehavior.execute(FlowNodeActivityBehavior.java:36)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationProcessStartInitial.eventNotificationsCompleted(AtomicOperationProcessStartInitial.java:45)
at org.activiti.engine.impl.pvm.runtime.AtomicOperationProcessStart.eventNotificationsCompleted(AtomicOperationProcessStart.java:64)
at org.activiti.engine.impl.persistence.entity.ExecutionEntity.start(ExecutionEntity.java:380)
at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:110)
at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:37)
at org.activiti.engine.impl.interceptor.CommandInvoker.execute(CommandInvoker.java:24)
at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:57)
at org.activiti.engine.impl.interceptor.LogInterceptor.execute(LogInterceptor.java:37)
at org.activiti.engine.impl.RuntimeServiceImpl.startProcessInstanceByKey(RuntimeServiceImpl.java:69)
at com.vega.activiti.Test.main(Test.java:25)
The process flow does not return to the main Process to the 2nd service task in the Main Process.I am not able to figure out the issue. Is it right to deploy and Start in the subprocess in the service task?Starting Main process:public class Test {
public static void main(String[] args) {
ProcessEngine processEngine = ProcessEngines.getDefaultProcessEngine();
RepositoryService repositoryService = processEngine.getRepositoryService();
repositoryService.createDeployment().addClasspathResource("helloworldprocess.bpmn20.xml").deploy();
RuntimeService runtimeService = processEngine.getRuntimeService();
ProcessInstance processInstance = runtimeService.startProcessInstanceByKey("helloworldprocess");
}Starting the subprocess from First service i.e HelloWorld Service.public class HelloWorld implements JavaDelegate {
try {
HashMap<String, Object> values = new HashMap<String, Object>();
values.put("inputMsg", "Start Subprocess");
EngineServices engineServices = execution.getEngineServices();
engineServices.getRepositoryService().createDeployment().addClasspathResource("helloworldSubProcess.bpmn20.xml").deploy();
ProcessInstance processInstance = engineServices.getRuntimeService()
.startProcessInstanceByKey("helloworldSubProcess", values);
} catch (Exception e) {
// TODO Auto-generated catch block
e.printStackTrace();
