Hi! I have following piece of code and it does very interesting things:
private Node getReportNode(Node noda) {
String path = noda.getPath();
path = path.replaceAll("\\{http://www.alfresco.org/model/application/1.0\\}", "app:");
path = path.replaceAll("\\{http://www.alfresco.org/model/content/1.0\\}", "cm:");
String query = "PATH:\"" + path + ".xml\"";
StoreRef storeRef = new StoreRef(StoreRef.PROTOCOL_WORKSPACE, "SpacesStore");
ResultSet resultSet = getSearchService().query(storeRef, SearchService.LANGUAGE_LUCENE, query);
for (ResultSetRow row : resultSet) {
Node foundNode = new Node(row.getNodeRef());
if (foundNode.hasAspect(ArchivaceModel.archProfileDescription))
return foundNode;
return null;
When I'm logged in as an Administrator, it works as expected. When I'm logged in as normal user, it does not work:
Unable to delete File due to system error: Failed to parse query: PATH:"/app:company_home/app:user_homes/{http://www.alfresco.org/model/system/1.0}xbalak00/cm:Profile/cm:kcab.png.xml"
So I found that I need to encode it as an ISO9075, I did:
String query = org.alfresco.util.ISO9075.encode("PATH:\"" + path + ".xml\"");
But it doesn't work, it finds nothing :-(. Where can be problem?Thanks in advance!
