Hi All,I have a existing ldap server , i have set the authentication.chain=alfrescoNtlm1:alfrescoNtlm to authentication.chain=myldap:ldap,alfrescoNtlm1:alfrescoNtlm in "alfresco-global.properties"my ldap server message is :Base provider URL: ldap://sample:10389Base DN: dc=userstore,dc=siteminderPrinciple: CN=mytest,OU=Service Accounts,OU=Domain Administration,OU=AM,DC=Userstore,DC=SiteminderCredential: 12345now ,i set /opt/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/subsystems/Authentication/ldap/myldap/ldap-authentication.properties below:
# This flag enables use of this LDAP subsystem for authentication. It may be
# that this subsytem should only be used for synchronization, in which case
# this flag should be set to false.
# This properties file brings together the common options for LDAP authentication rather than editing the bean definitions
# How to map the user id entered by the user to that passed through to LDAP
# - simple
# - this must be a DN and would be something like
# uid=%s,ou=People,dc=company,dc=com
# - digest
# - usually pass through what is entered
# %s
# If not set, an LDAP query involving ldap.synchronization.personQuery and ldap.synchronization.userIdAttributeName will
# be performed to resolve the DN dynamically. This allows directories to be structured and doesn't require the user ID to
# appear in the DN.
ldap.authentication.userNameFormat=uid=%s,ou=Service Accounts,ou=Domain Administration,ou=AM,dc=Userstore,dc=Siteminder
# The LDAP context factory to use
# The URL to connect to the LDAP server
ldap.authentication.java.naming.provider.url=ldap://sample:10389
# The authentication mechanism to use
# Escape commas entered by the user at bind time
# Useful when using simple authentication and the CN is part of the DN and contains commas
# Escape commas entered by the user when setting the authenticated user
# Useful when using simple authentication and the CN is part of the DN and contains commas, and the escaped \, is
# pulled in as part of an LDAP sync
# If this option is set to true it will break the default home folder provider as space names can not contain \
# Comma separated list of user names who should be considered administrators by default
ldap.authentication.defaultAdministratorUserNames=evan
# This flag enables use of this LDAP subsystem for user and group
# synchronization. It may be that this subsytem should only be used for
# authentication, in which case this flag should be set to false.
# The default principal to use (only used for LDAP sync)
ldap.synchronization.java.naming.security.principal=cn=mytest,ou=Service Accounts,ou=Domain Administration,ou=AM,dc=Userstore,dc=Siteminder
# The password for the default principal (only used for LDAP sync)
ldap.synchronization.java.naming.security.credentials=12345
# If positive, this property indicates that RFC 2696 paged results should be
# used to split query results into batches of the specified size. This
# overcomes any size limits imposed by the LDAP server.
# The query to select all objects that represent the groups to import.
#ldap.synchronization.groupQuery=(objectclass\=groupOfNames)
# The query to select objects that represent the groups to import that have changed since a certain time.
#ldap.synchronization.groupDifferentialQuery=(&(objectclass\=groupOfNames)(!(modifyTimestamp<\={0})))
# The query to select all objects that represent the users to import.
ldap.synchronization.personQuery=(objectclass\=userProxy)
# The query to select objects that represent the users to import that have changed since a certain time.
ldap.synchronization.personDifferentialQuery=(&(objectclass\=userproxy)(!(modifyTimestamp<\={0})))
# The group search base restricts the LDAP group query to a sub section of tree on the LDAP server.
#ldap.synchronization.groupSearchBase=ou\=Groups,dc\=company,dc\=com
# The user search base restricts the LDAP user query to a sub section of tree on the LDAP server.
ldap.synchronization.userSearchBase=ou\=AP,dc\=userstore,dc\=siteminder
# The name of the operational attribute recording the last update time for a group or user.
# The timestamp format. Unfortunately, this varies between directory servers.
ldap.synchronization.timestampFormat=yyyyMMddHHmmss'Z'
# The attribute name on people objects found in LDAP to use as the uid in Alfresco
ldap.synchronization.userIdAttributeName=uid
# The attribute on person objects in LDAP to map to the first name property in Alfresco
# The attribute on person objects in LDAP to map to the last name property in Alfresco
# The attribute on person objects in LDAP to map to the email property in Alfresco
# The attribute on person objects in LDAP to map to the organizational id property in Alfresco
#ldap.synchronization.userOrganizationalIdAttributeName=o
# The default home folder provider to use for people created via LDAP import
ldap.synchronization.defaultHomeFolderProvider=userHomesHomeFolderProvider
# The attribute on LDAP group objects to map to the gid property in Alfrecso
# The group type in LDAP
#ldap.synchronization.groupType=groupOfNames
# The person type in LDAP
#ldap.synchronization.personType=inetOrgPerson
# The attribute in LDAP on group objects that defines the DN for its members
#ldap.synchronization.groupMemberAttributeName=member
# If true progress estimation is enabled. When enabled, the user query has to be run twice in order to count entries.
1. I hope to know ,where is wrong in my ldap-authentication.properties 2. have other properties file need i to set?3. where and how to set the ldap.synchronization.defaultHomeFolderProvider=userHomesHomeFolderProvider to run?thanks all.
