Hi everyone,I have the following issue:I'm using Java(TM) SE Runtime Environment (build 1.6.0_20-b02) on ubuntu and runnning Alfresco 3.2r2 (plus Share). When I run Alfresco for the first time, alfresco.war is deploying ok.I'm using S-IDE Labs to build custom modules and integrate them to my alfresco instance. My modules have nothing to deal with the audit system. Also, I disabled audit in /alfresco/WEB-INF/classes/alfresco/repository.properties with :
audit.enabled=false
audit.useNewConfig=false
On the second launch, I have the following error:
29 juin 2010 16:45:00 org.apache.coyote.http11.Http11Protocol init
INFO: Initialisation de Coyote HTTP/1.1 sur http-8080
29 juin 2010 16:45:00 org.apache.catalina.startup.Catalina load
INFO: Initialization processed in 423 ms
29 juin 2010 16:45:00 org.apache.catalina.core.StandardService start
INFO: D�marrage du service Catalina
29 juin 2010 16:45:00 org.apache.catalina.core.StandardEngine start
29 juin 2010 16:45:03 org.apache.catalina.core.StandardContext addApplicationListener
16:45:08,300 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
16:45:08,302 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
16:45:08,302 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/home/christophe/alfresco32r2/tomcat/shared/classes/alfresco-global.properties]
16:45:08,402 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:26,591 INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
16:45:27,255 INFO [domain.schema.SchemaBootstrap] No changes were made to the schema.
16:45:27,553 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'sysAdmin' subsystem, ID: [sysAdmin, default]
16:45:27,563 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:27,567 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'sysAdmin' subsystem, ID: [sysAdmin, default] complete
16:45:30,112 User:System INFO [management.subsystems.ChildApplicationContextFactory] Starting 'thirdparty' subsystem, ID: [thirdparty, default]
16:45:30,125 User:System INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:30,203 User:System ERROR [transform.magick.AbstractImageMagickContentTransformerWorker] ImageMagickContentTransformerWorker not available: 05290000 Failed to perform ImageMagick transformation:
Execution result:
os: Linux
command: [./ImageMagick/bin/convert, /home/christophe/alfresco32r2/tomcat/temp/Alfresco/ImageMagickContentTransformerWorker_init_source_2098889747991900200.gif[0], /home/christophe/alfresco32r2/tomcat/temp/Alfresco/ImageMagickContentTransformerWorker_init_target_5286656465253742657.png]
succeeded: false
exit code: 1
out:
err: Cannot run program "./ImageMagick/bin/convert": java.io.IOException: error=2, No such file or directory
16:45:30,254 User:System ERROR [content.transform.RuntimeExecutableContentTransformerWorker] Failed to start a runtime executable content transformer:
Execution result:
os: Linux
command: [./bin/pdf2swf, -V]
succeeded: false
exit code: 1
out:
err: Cannot run program "./bin/pdf2swf": java.io.IOException: error=2, No such file or directory
16:45:30,509 User:System WARN [alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
16:45:30,510 User:System INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'thirdparty' subsystem, ID: [thirdparty, default] complete
16:45:31,150 INFO [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: /home/christophe/alfresco32r2/tomcat/alf_data
16:45:31,396 INFO [admin.patch.PatchExecuter] Checking for patches to apply …
16:45:31,690 INFO [admin.patch.PatchExecuter] No patches were required.
16:45:31,698 User:System INFO [repo.module.ModuleServiceImpl] Found 6 module(s).
16:45:31,819 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_alfresco_ifremer_imap' version 1.0.0.
16:45:31,878 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_WorkflowExtension_IfremerSimple_Process' version 1.0.
16:45:31,925 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_alfresco_site_group' version 1.0.0.
16:45:31,974 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_xforms' version 1.0.54.
16:45:32,024 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_WorkflowExtension_ifremer_Process' version 1.0.
16:45:32,074 User:System INFO [repo.module.ModuleServiceImpl] Starting module 'SIDE_pdfGenerator' version 1.0.32.
16:45:32,559 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'fileServers' subsystem, ID: [fileServers, default]
16:45:32,582 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:32,802 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1]
16:45:32,815 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:32,897 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Authentication' subsystem, ID: [Authentication, managed, alfrescoNtlm1] complete
16:45:37,915 ERROR [org.alfresco.fileserver] Failed to get local domain/workgroup name, using default of WORKGROUP
16:45:37,915 ERROR [org.alfresco.fileserver] (This may be due to firewall settings or incorrect <broadcast> setting)
16:45:37,946 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'fileServers' subsystem, ID: [fileServers, default] complete
16:45:37,946 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'imap' subsystem, ID: [imap, default]
16:45:37,946 ERROR [org.alfresco.fileserver] [SMB] Server error : org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Permission denied
16:45:37,948 ERROR [org.alfresco.fileserver] org.alfresco.jlan.server.config.InvalidConfigurationException: Error initializing TCP-IP SMB session handler, Permission denied
16:45:37,948 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.smb.server.nio.NIOCifsConnectionsHandler.initializeHandler(NIOCifsConnectionsHandler.java:265)
16:45:37,948 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.smb.server.SMBServer.run(SMBServer.java:478)
16:45:37,949 ERROR [org.alfresco.fileserver] at java.lang.Thread.run(Thread.java:619)
16:45:37,953 ERROR [org.alfresco.fileserver] [FTP] FTP Socket error : java.net.BindException: Permission denied
16:45:37,953 ERROR [org.alfresco.fileserver] java.net.BindException: Permission denied
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.PlainSocketImpl.socketBind(Native Method)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.PlainSocketImpl.bind(PlainSocketImpl.java:365)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.bind(ServerSocket.java:319)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.<init>(ServerSocket.java:185)
16:45:37,953 ERROR [org.alfresco.fileserver] at java.net.ServerSocket.<init>(ServerSocket.java:141)
16:45:37,965 ERROR [org.alfresco.fileserver] at org.alfresco.jlan.ftp.FTPServer.run(FTPServer.java:561)
16:45:37,965 ERROR [org.alfresco.fileserver] at java.lang.Thread.run(Thread.java:619)
16:45:37,964 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:38,056 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'imap' subsystem, ID: [imap, default] complete
16:45:38,062 INFO [repo.usage.UserUsageTrackingComponent] Enabled - calculate missing user usages …
16:45:38,084 INFO [repo.usage.UserUsageTrackingComponent] Found 0 users to recalculate
16:45:38,084 INFO [repo.usage.UserUsageTrackingComponent] … calculated missing usages for 0 users
16:45:38,084 INFO [management.subsystems.ChildApplicationContextFactory] Starting 'Synchronization' subsystem, ID: [Synchronization, default]
16:45:38,105 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
16:45:38,236 INFO [management.subsystems.ChildApplicationContextFactory] Startup of 'Synchronization' subsystem, ID: [Synchronization, default] complete
16:45:38,366 ERROR [web.context.ContextLoader] Context initialization failed
org.alfresco.repo.audit.model.AuditModelException: 05290002 Failed to load audit model: file:/home/christophe/alfresco32r2/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/audit/alfresco-audit-repository.xml
at org.alfresco.repo.audit.model.AuditModelRegistry$1.execute(AuditModelRegistry.java:258)
at org.alfresco.repo.audit.model.AuditModelRegistry$1.execute(AuditModelRegistry.java:238)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:327)
at org.alfresco.repo.audit.model.AuditModelRegistry.loadAuditModels(AuditModelRegistry.java:276)
at org.alfresco.repo.audit.AuditBootstrap$1.execute(AuditBootstrap.java:64)
at org.alfresco.repo.audit.AuditBootstrap$1.execute(AuditBootstrap.java:62)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:253)
at org.alfresco.repo.audit.AuditBootstrap.onBootstrap(AuditBootstrap.java:68)
at org.springframework.context.support.AbstractApplicationContext.finishRefresh(AbstractApplicationContext.java:617)
Caused by: org.alfresco.error.AlfrescoRuntimeException: 05290001 Failed to load Alfresco Audit Schema from classpath:alfresco/audit/alfresco-audit-3.2.xsd
at org.alfresco.repo.audit.model.AuditModelRegistry.unmarshallModel(AuditModelRegistry.java:385)
at org.alfresco.repo.audit.model.AuditModelRegistry.unmarshallModel(AuditModelRegistry.java:344)
at org.alfresco.repo.audit.model.AuditModelRegistry$1.execute(AuditModelRegistry.java:246)
… 43 more
Caused by: java.lang.NoSuchMethodError: org.apache.xerces.impl.xs.XMLSchemaLoader.loadGrammar([Lorg/apache/xerces/xni/parser/XMLInputSource;)V
at org.apache.xerces.jaxp.validation.XMLSchemaFactory.newSchema(Unknown Source)
at javax.xml.validation.SchemaFactory.newSchema(SchemaFactory.java:594)
at javax.xml.validation.SchemaFactory.newSchema(SchemaFactory.java:626)
at org.alfresco.repo.audit.model.AuditModelRegistry.unmarshallModel(AuditModelRegistry.java:363)
… 45 more
29 juin 2010 16:45:38 org.apache.catalina.core.StandardContext start
GRAVE: Error listenerStart
GRAVE: Erreur de d�marrage du contexte [/alfresco] suite aux erreurs pr�c�dentes
And the above mentioned files are still in my alfresco webapp.Can someone point me to an already related and answered post (not the one for windows as there is no answer for this problem) or give me help for this error?Thanks in advance.—CLoisel
