Hello!I'm trying to install Alfresco 3.3g on a Linux system. I first tried it on a Debian server with no graphical user interface. I tried out different installation methods I found on the web including the one for debian in the Alfresco wiki. I then tried installing Alfresco on my Ubuntu 10.04 system with the graphical installer. I ended up having the same error. So here is where I am:Webinterface:/share: The login appears, but login fails with admin/admin/alfresco: Does not work. I get the following error message: The requested resource () is not available.I checked the alfresco.log. Here, an exception occours loading the springframework. I guess that might be the problem:21:48:48,613 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/repository.properties]
21:48:48,630 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/transaction.properties]
21:48:48,638 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from file [/opt/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/module/tests/alfresco-global.properties]
21:48:48,641 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from file [/opt/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/module/test/alfresco-global.properties]
21:48:48,642 INFO [org.alfresco.config.JndiPropertiesFactoryBean] Loading properties file from URL [file:/opt/Alfresco/tomcat/shared/classes/alfresco-global.properties]
21:48:48,704 INFO [org.alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
21:48:58,010 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'webscripts.abdera' defined in URL [jar:file:/opt/Alfresco/tomcat/webapps/alfresco/WEB-INF/lib/spring-webscripts-1.0.0.CI-SNAPSHOT.jar!/org/springframework/extensions/webscripts/spring-webscripts-application-context.xml]: Invocation of init method failed; nested exception is java.lang.NoClassDefFoundError: org/apache/abdera/i18n/text/io/FilteredCharReader
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1401)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:512)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:261)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:192)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:637)
at org.apache.catalina.startup.HostConfig.deployDescriptors(HostConfig.java:563)
at org.apache.catalina.startup.HostConfig.deployApps(HostConfig.java:498)
at java.lang.reflect.Method.invoke(Method.java:616)
Caused by: java.lang.NoClassDefFoundError: org/apache/abdera/i18n/text/io/FilteredCharReader
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(ClassLoader.java:634)
at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
at org.apache.catalina.loader.WebappClassLoader.findClassInternal(WebappClassLoader.java:2527)
at org.apache.catalina.loader.WebappClassLoader.findClass(WebappClassLoader.java:1010)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1483)
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1361)
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:2406)
at java.lang.Class.getConstructor0(Class.java:2716)
at java.lang.Class.getConstructor(Class.java:1674)
at org.apache.abdera.util.ServiceUtil._create(ServiceUtil.java:175)
at org.apache.abdera.util.ServiceUtil.locateInstance(ServiceUtil.java:229)
at org.apache.abdera.util.ServiceUtil.locateInstance(ServiceUtil.java:222)
at org.apache.abdera.util.ServiceUtil.locate(ServiceUtil.java:144)
at org.apache.abdera.util.ServiceUtil.newInstance(ServiceUtil.java:58)
at org.apache.abdera.util.ServiceUtil.newParserInstance(ServiceUtil.java:87)
at org.apache.abdera.util.AbderaConfiguration.newParserInstance(AbderaConfiguration.java:282)
at org.apache.abdera.Abdera.newParser(Abdera.java:219)
at org.apache.abdera.Abdera.<init>(Abdera.java:91)
at org.apache.abdera.Abdera.<init>(Abdera.java:81)
at org.springframework.extensions.webscripts.atom.AbderaServiceImpl.afterPropertiesSet(AbderaServiceImpl.java:78)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1460)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1398)
… 37 more
Caused by: java.lang.ClassNotFoundException: org.apache.abdera.i18n.text.io.FilteredCharReader
at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1516)
… 68 more
21:49:02,600 INFO [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 227 Web Scripts (+0 failed), 235 URLs
21:49:02,601 INFO [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 8 Package Description Documents (+0 failed)
21:49:02,601 INFO [org.springframework.extensions.webscripts.DeclarativeRegistry] Registered 0 Schema Description Documents (+0 failed)
21:49:02,664 INFO [org.springframework.extensions.webscripts.AbstractRuntimeContainer] Initialised Spring Surf Container Web Script Container (in 881.32904ms)
21:49:02,703 INFO [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
21:49:02,757 INFO [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
21:49:02,804 INFO [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
21:49:02,807 INFO [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
21:49:02,869 INFO [org.springframework.extensions.webscripts.TemplateProcessorRegistry] Registered template processor freemarker for extension ftl
21:49:02,872 INFO [org.springframework.extensions.webscripts.ScriptProcessorRegistry] Registered script processor javascript for extension js
Checking the MySQL database, there was nothing in there. I created the database and user as necessary. I don't know wheter that's normal, but I found it strange that there were no tables and and no content created at all after starting alfresco.Java versions I used:# debian system
java version "1.6.0_20"
Java(TM) SE Runtime Environment (build 1.6.0_20-b02)
Java HotSpot(TM) Client VM (build 16.3-b01, mixed mode, sharing)
#ubuntu system
java version "1.6.0_18"
OpenJDK Runtime Environment (IcedTea6 1.8) (6b18-1.8-4ubuntu3)
OpenJDK 64-Bit Server VM (build 16.0-b13, mixed mode)
I hope someone can help me with this. Searching the web didn't help me yet.Thank you,jeb
