# Alfresco init script for Ubuntu # 2 nov 2007 Joost Horward # export JAVA_HOME="/usr/lib/jvm/java-6-sun" ## NEU!! export JRE_HOME="/usr/lib/jvm/java-6-sun" ## NEU!! export ALFRESCO_HOME=/opt/alfresco export CATALINA_BASE=/opt/alfresco/tomcat export CATALINA_HOME=/opt/alfresco/tomcat export PIDFILE=/var/run/alfresco export LOGFILE=/var/log/alfresco/alfresco.log # Set any default JVM values export JAVA_OPTS='-Xms128m -Xmx512m -server -Djava.io.tmpdir=/var/lib/alfresco/tmp' export JAVA_OPTS="${JAVA_OPTS} -Djava.rmi.server.hostname=localhost" ## NEU !!
HTTP Status 404 - /alfresco/ type Status report message /alfresco/ description The requested resource (/alfresco/) is not available. Apache Tomcat/5.5.23
root@nxxxx999:/var/log/alfresco/tomcat/logs# cat cat* 07.08.2008 10:05:22 org.apache.coyote.http11.Http11BaseProtocol init INFO: Initializing Coyote HTTP/1.1 on http-8080 07.08.2008 10:05:22 org.apache.catalina.startup.Catalina load INFO: Initialization processed in 830 ms 07.08.2008 10:05:22 org.apache.catalina.core.StandardService start INFO: Starting service Catalina 07.08.2008 10:05:22 org.apache.catalina.core.StandardEngine start INFO: Starting Servlet Engine: Apache Tomcat/5.5.23 07.08.2008 10:05:22 org.apache.catalina.core.StandardHost start INFO: XML validation disabled 07.08.2008 10:05:23 org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive share.war 07.08.2008 10:05:25 org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive alfresco.war 07.08.2008 10:05:41 org.apache.catalina.core.StandardContext start SCHWERWIEGEND: Error listenerStart 07.08.2008 10:05:41 org.apache.catalina.core.StandardContext start SCHWERWIEGEND: Context [/alfresco] startup failed due to previous errors 07.08.2008 10:05:43 org.apache.coyote.http11.Http11BaseProtocol start INFO: Starting Coyote HTTP/1.1 on http-8080 07.08.2008 10:05:43 org.apache.catalina.storeconfig.StoreLoader load INFO: Find registry server-registry.xml at classpath resource 07.08.2008 10:05:43 org.apache.catalina.startup.Catalina start INFO: Server startup in 21205 ms 07.08.2008 10:05:22 org.apache.coyote.http11.Http11BaseProtocol init INFO: Initializing Coyote HTTP/1.1 on http-8080 07.08.2008 10:05:22 org.apache.catalina.startup.Catalina load INFO: Initialization processed in 830 ms 07.08.2008 10:05:22 org.apache.catalina.core.StandardService start INFO: Starting service Catalina 07.08.2008 10:05:22 org.apache.catalina.core.StandardEngine start INFO: Starting Servlet Engine: Apache Tomcat/5.5.23 07.08.2008 10:05:22 org.apache.catalina.core.StandardHost start INFO: XML validation disabled 07.08.2008 10:05:23 org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive share.war 10:05:25,477 INFO [web.site.FrameworkHelper] Successfully Initialized Web Framework 07.08.2008 10:05:25 org.apache.catalina.startup.HostConfig deployWAR INFO: Deploying web application archive alfresco.war 10:05:37,845 INFO [config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties] 10:05:39,255 WARN [remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one Cannot load JDBC driver class 'org.gjt.mm.mysql.Driver' java.lang.ClassNotFoundException: org.gjt.mm.mysql.Driver at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1359) at org.apache.catalina.loader.WebappClassLoader.loadClass(WebappClassLoader.java:1205) at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319) at java.lang.Class.forName0(Native Method) at java.lang.Class.forName(Class.java:169) at org.apache.commons.dbcp.BasicDataSource.createDataSource(BasicDataSource.java:760) at org.apache.commons.dbcp.BasicDataSource.getConnection(BasicDataSource.java:540) at org.springframework.orm.hibernate3.LocalDataSourceConnectionProvider.getConnection(LocalDataSourceConnectionProvider.java:81) at org.hibernate.cfg.SettingsFactory.buildSettings(SettingsFactory.java:76) at org.hibernate.cfg.Configuration.buildSettings(Configuration.java:2006) at org.hibernate.cfg.Configuration.buildSessionFactory(Configuration.java:1289) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.newSessionFactory(LocalSessionFactoryBean.java:804) at org.springframework.orm.hibernate3.LocalSessionFactoryBean.buildSessionFactory(LocalSessionFactoryBean.java:744) at org.springframework.orm.hibernate3.AbstractSessionFactoryBean.afterPropertiesSet(AbstractSessionFactoryBean.java:131) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.invokeInitMethods(AbstractAutowireCapableBeanFactory.java:1118) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1085) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:429) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247) at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:245) at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:124) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1019) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:809) at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:425) at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250) at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
10:43:21,941 WARN [remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one 10:43:26,521 ERROR [transform.swf.PDFToSWFContentTransformer] Failed to start SWF2PDF transformer: Execution result: os: Linux command: pdf2swf -V succeeded: false exit code: 1 out: err: Cannot run program "pdf2swf": java.io.IOException: error=2, No such file or directory
10:43:28,093 INFO [domain.schema.SchemaBootstrap] Executing database script /opt/alfresco/tomcat/temp/Alfresco/AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-59782.sql (Copied from classpath:alfresco/dbscripts/upgrade/1.4/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoSchemaUpdate-1.4-1.sql). 10:43:28,111 ERROR [domain.schema.SchemaBootstrap] Statement execution failed: SQL: ALTER TABLE applied_patch ENGINE = InnoDB Error: Table 'alfresco.applied_patch' doesn't exist File: /opt/alfresco/tomcat/temp/Alfresco/AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-59782.sql Line: 31 10:43:28,113 ERROR [domain.schema.SchemaBootstrap] Schema auto-update failed
rm -r /var/lib/alfresco/alf_data/*
mysql -u root -p
drop database alfresco;
create database alfresco;
grant all privileges on alfresco.* to alfresco@localhost identified by 'alfresco';
