BUILD FAILEDC:\usr\src\Alfresco-HEAD\root\projects.xml:199: JiBXException in JiBX binding compilation at org.jibx.binding.ant.CompileTask.execute(CompileTask.java:252) at org.apache.tools.ant.UnknownElement.execute(UnknownElement.java:275) at org.apache.tools.ant.Task.perform(Task.java:364) at org.apache.tools.ant.Target.execute(Target.java:341) at org.apache.tools.ant.Target.performTasks(Target.java:369) at org.apache.tools.ant.Project.executeSortedTargets(Project.java:1216) at org.apache.tools.ant.Project.executeTarget(Project.java:1185) at org.apache.tools.ant.helper.DefaultExecutor.executeTargets(DefaultExecutor.java:40) at org.apache.tools.ant.Project.executeTargets(Project.java:1068) at org.apache.tools.ant.Main.runBuild(Main.java:668) at org.apache.tools.ant.Main.startAnt(Main.java:187) at org.apache.tools.ant.launch.Launcher.run(Launcher.java:246) at org.apache.tools.ant.launch.Launcher.main(Launcher.java:67)Caused by: org.jibx.runtime.JiBXException: Error running binding compiler at org.jibx.binding.Compile.compile(Compile.java:321) at org.jibx.binding.ant.CompileTask.execute(CompileTask.java:248) … 12 more— Nested Exception —Error running binding compilerjava.lang.NoClassDefFoundError: org/alfresco/error/AlfrescoRuntimeException at java.lang.ClassLoader.defineClass1(Native Method)
<target name="compile-repository-jibx" depends="init"> <!– load the JIBX task definition –> <taskdef name="bind" classname="org.jibx.binding.ant.CompileTask" classpath="${dir.project.3rdparty.lib}/jibx/jibx-bind.jar;${dir.project.3rdparty.lib}/jibx/jibx-run.jar;${dir.project.3rdparty.lib}/bcel.jar;${dir.project.3rdparty.lib}/xpp3-1.1.3_8.jar" /> <bind verbose="false" load="true" binding="${file.jibx.binding.m2}"> <classpathset dir="${dir.project.repository.classes}"/> <classpathset dir="${dir.project.core.classes}"/> </bind> <bind verbose="false" load="true" binding="${file.jibx.binding.systeminfo}"> <classpathset dir="${dir.project.repository.classes}"/> <classpathset dir="${dir.project.core.classes}"/> </bind> </target>
