Hi again
two posts this day…I was using until today the Alfresco SDK 3 Stable from SourceForge. Used to work well with a few fixes. I decided today to play with the SVN version.Everything worked fine until I ran the SDK FirstFoundationClient project. Strange things happened : here's the log from Eclipse :
17:47:22,593 INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
17:47:23,343 INFO [alfresco.config.JndiPropertiesFactoryBean] Loading properties file from class path resource [alfresco/domain/hibernate-cfg.properties]
17:47:35,828 INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
17:47:36,937 INFO [domain.schema.SchemaBootstrap] Executing database script C:\DOCUME~1\bedeaub\LOCALS~1\Temp\Alfresco\AlfrescoSchema-MySQLInnoDBDialect-Update-8669142084738288324.sql (Copied from classpath:alfresco/dbscripts/upgrade/2.2/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoSchemaUpdate-Person.sql).
17:47:37,046 INFO [domain.schema.SchemaBootstrap] Executing database script C:\DOCUME~1\bedeaub\LOCALS~1\Temp\Alfresco\AlfrescoSchema-MySQLInnoDBDialect-Update-7615510242104074000.sql (Copied from classpath:alfresco/dbscripts/create/3.2/org.hibernate.dialect.MySQLInnoDBDialect/AlfrescoPostCreate-3.2-LockTables.sql).
17:47:37,921 INFO [domain.schema.SchemaBootstrap] Executing database script C:\DOCUME~1\bedeaub\LOCALS~1\Temp\Alfresco\AlfrescoSchema-MySQLInnoDBDialect-Update-2701564815722804772.sql (Copied from classpath:alfresco/dbscripts/upgrade/3.2/org.hibernate.dialect.MySQLInnoDBDialect/remove-AVM-issuer.sql).
17:47:38,375 INFO [domain.schema.SchemaBootstrap] All executed statements: C:\DOCUME~1\bedeaub\LOCALS~1\Temp\Alfresco\AlfrescoSchema-MySQLInnoDBDialect-All_Statements-4931947912673377590.sql.
17:47:39,125 INFO [domain.schema.SchemaBootstrap] Normalized schema (pre-bootstrap) dumped to file C:\DOCUME~1\bedeaub\LOCALS~1\Temp\Alfresco\AlfrescoSchema-MySQLInnoDBDialect-814643589718943040-Startup.xml.
17:47:39,125 INFO [domain.schema.SchemaBootstrap] Normalized schema (post-bootstrap) dumped to file C:\DOCUME~1\bedeaub\LOCALS~1\Temp\Alfresco\AlfrescoSchema-MySQLInnoDBDialect-3203957614568981738.xml.
17:47:41,093 User:System INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
17:47:42,656 User:System INFO [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: c:\alfresco\alf_data
17:47:42,703 User:System INFO [admin.patch.PatchExecuter] Checking for patches to apply …
17:47:43,218 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.redeploySubmitProcess5' (Re-deploy WCM Submit Process Definition.).
17:47:43,578 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.deploySubmitDirectProcess' (Deploy WCM Direct Submit Process Definition.).
17:47:43,687 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.moveWCMToGroupBasedPermissionsPatch' (Move WCM to group based permissions.).
17:47:43,734 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.wcmPostPermissionSnapshotPatch2' (Snapshot stores (after fixing ACLs so they are only set on the staging area store).).
17:47:43,984 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.redeploySubmitProcess6' (Re-deploy WCM Submit Process Definition.).
17:47:44,343 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.redeploySubmitProcess7' (Re-deploy WCM Submit Process Definition.).
17:47:44,625 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.migrateVersionStoreUpdateCounter' (Update internal version2Store counter (if needed).).
17:47:44,703 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.webSiteAddModerated' (Changing Web Site visibility from a boolean to enum.).
17:47:44,750 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.invitationMigration' (Migrate invitations from old invite service to invitation service).
17:47:44,750 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.mtShareExistingTenants' (Update existing tenants for MT Share.).
17:47:44,906 User:System INFO [admin.patch.PatchExecuter] Applying patch 'patch.redeployInvitationProcess' (Re-deploy Invitation Process Definitions.).
17:47:45,062 User:System INFO [admin.patch.PatchExecuter]
=== Applied patch ===
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Script completed
RESULT:
Re-deployed 1 workflows.
RESULT:
Update internal version2Store counter (if needed): oldV1count=0,oldV2count=0,newV2count=0
RESULT:
WCM moved to group based permissions.
RESULT:
Patch applied, although no changes made since MT is not enabled.
RESULT:
Re-deployed 2 workflows.
RESULT:
RESULT:
RESULT:
RESULT:
Snapshot complete after WCM ACL changes.
RESULT:
Changed Web Site visibility.
17:47:45,062 User:System INFO [repo.module.ModuleServiceImpl] Found 0 module(s).
17:47:45,187 User:System WARN [repo.module.ModuleServiceImpl] A previously-installed module 'org.alfresco.module.vti' (version 1.0) is not present in your distribution.
17:47:45,234 User:System INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
17:47:45,531 User:System INFO [alfresco.config.JndiPropertyPlaceholderConfigurer] Loading properties file from class path resource [alfresco/alfresco-shared.properties]
17:47:45,906 User:System INFO [service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_13-b03; maximum heap size 1016,125MB
17:47:45,906 User:System INFO [service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.2.0 (_Preview2_dev @build-number@) schema 2011 - Installed version 3.0.0 (Stable 1526) schema 1002
What the hell are these "patches" ?Usually, when I ran the SDK FirstFoundationClient from the SDK I had the following output :
17:43:22,093 INFO [config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
17:43:24,859 INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
17:43:25,531 INFO [domain.schema.SchemaBootstrap] No changes were made to the schema.
17:43:27,109 User:System INFO [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: C:\Alfresco\alf_data
17:43:27,140 User:System INFO [admin.patch.PatchExecuter] Checking for patches to apply …
17:43:27,296 User:System INFO [admin.patch.PatchExecuter] No patches were required.
17:43:27,296 User:System INFO [repo.module.ModuleServiceImpl] Found 0 module(s).
17:43:27,343 User:System WARN [repo.module.ModuleServiceImpl] A previously-installed module 'org.alfresco.module.vti' (version 1.0) is not present in your distribution.
17:43:28,562 User:System WARN [alfresco.util.OpenOfficeConnectionTester] An initial OpenOffice connection could not be established.
17:43:28,609 User:System INFO [service.descriptor.DescriptorService] Alfresco JVM - v1.6.0_13-b03; maximum heap size 1016,125MB
17:43:28,609 User:System INFO [service.descriptor.DescriptorService] Alfresco started (Labs): Current version 3.0.0 (Stable 1526) schema 1002 - Installed version 3.0.0 (Stable 1526) schema 1002
I felt like something weird just happened…And I was right : I tried to run alfresco just after that :
17:49:31,125 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
17:49:39,468 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.
17:49:40,296 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Exécution du script de base de données C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-8420358068760992259.sql (généré)
17:49:40,375 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Tous les instructions exécutées sont journalisées dans le fichier C:\Alfresco\tomcat\temp\Alfresco\AlfrescoSchemaUpdate-All_Statements-3766312784026750636.sql.
17:49:40,703 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
java.lang.RuntimeException: Error during run with lock.
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.doWithFileLock(IndexInfo.java:2251)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.<init>(IndexInfo.java:557)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.getIndexInfo(IndexInfo.java:351)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneBase.initialise(AbstractLuceneBase.java:106)
at org.alfresco.repo.search.impl.lucene.ADMLuceneSearcherImpl.getSearcher(ADMLuceneSearcherImpl.java:129)
at org.alfresco.repo.search.impl.lucene.ADMLuceneIndexerAndSearcherFactory.getSearcher(ADMLuceneIndexerAndSearcherFactory.java:116)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory.getSearcher(AbstractLuceneIndexerAndSearcherFactory.java:463)
at org.alfresco.repo.search.impl.lucene.AbstractLuceneIndexerAndSearcherFactory.getSearcher(AbstractLuceneIndexerAndSearcherFactory.java:87)
at org.alfresco.repo.service.StoreRedirectorProxyFactory$RedirectorInvocationHandler.invoke(StoreRedirectorProxyFactory.java:221)
at $Proxy27.getSearcher(Unknown Source)
at org.alfresco.repo.search.SearcherComponent.selectNodes(SearcherComponent.java:107)
at org.alfresco.repo.search.AbstractSearcherComponent.selectNodes(AbstractSearcherComponent.java:77)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:296)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:177)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:166)
at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:49)
at org.alfresco.repo.audit.AuditComponentImpl.audit(AuditComponentImpl.java:275)
at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:69)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:107)
at $Proxy20.selectNodes(Unknown Source)
at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap.initDictionary(DictionaryRepositoryBootstrap.java:242)
at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap$1.execute(DictionaryRepositoryBootstrap.java:207)
at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:320)
at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap.init(DictionaryRepositoryBootstrap.java:203)
at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap$2.doWork(DictionaryRepositoryBootstrap.java:395)
at org.alfresco.repo.security.authentication.AuthenticationUtil.runAs(AuthenticationUtil.java:437)
at org.alfresco.repo.dictionary.DictionaryRepositoryBootstrap.onBootstrap(DictionaryRepositoryBootstrap.java:391)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:244)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:187)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:830)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:719)
Caused by: java.io.IOException: Unknown format version: -7
at org.apache.lucene.index.SegmentInfos.read(SegmentInfos.java:195)
at org.apache.lucene.index.IndexReader$1.doBody(IndexReader.java:152)
at org.apache.lucene.index.SegmentInfos$FindSegmentsFile.run(SegmentInfos.java:579)
at org.apache.lucene.index.IndexReader.open(IndexReader.java:147)
at org.apache.lucene.index.IndexReader.open(IndexReader.java:142)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.buildReferenceCountingIndexReader(IndexInfo.java:1927)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.access$1200(IndexInfo.java:127)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo$2.doWork(IndexInfo.java:618)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.doWithFileLock(IndexInfo.java:2320)
at org.alfresco.repo.search.impl.lucene.index.IndexInfo.doWithFileLock(IndexInfo.java:2240)
… 73 more
17:49:44,656 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
17:49:46,703 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
17:49:46,718 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 355.64462ms)
17:50:47,750 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
17:50:47,750 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 61023.312ms)
17:50:47,796 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
Huuum 'error during run with lock' didn't sound good to me. I restarted my PC (running Win XP SP3), but Alfresco still send me this error. I had to delete the database, delete alf_data content and recreate the database to "fix" the problem. But then I re-run the SVN project…Aaaand broke my Alfresco again
Any idea
?Thanks a lot !!!Good evening
