While I have db.schema.update=true, it's not creating at least one table that it needs during and an upgrade from 2.1CE to Labs 3c with MySQL.So it fails saying "Table 'alfresco.alf_usage_delta' doesn't exist."It looks like there's no 3.0 dbscripts, so it's a problem with the 2.2 dbscripts. upgrade-from-2.1.sql assumes that alf_usage_delta exists and there's no create script for it. I guess I'll just create the table and see how far it gets.The error:10:08:54,775 ERROR [domain.schema.SchemaBootstrap] Statement execution failed:
SQL: INSERT INTO t_alf_usage_delta
id, version,
node_id,
delta_size
SELECT
ud.id, 1,
ud.node_id,
ud.delta_size
FROM
alf_usage_delta ud
Error: Table 'alfresco.alf_usage_delta' doesn't exist
File: /usr/local/tomcat/temp/Alfresco/AlfrescoSchemaUpdate-org.hibernate.dialect.MySQLInnoDBDialect-8962.sql
Line: 441
10:08:54,777 ERROR [domain.schema.SchemaBootstrap] Schema auto-update failed
com.mysql.jdbc.exceptions.MySQLSyntaxErrorException: Table 'alfresco.alf_usage_delta' doesn't exist
