Hi all!first and foremost, description.Machine A _> AlfrescoMachie b -> SQLMachine c-> Alf_dataMachine d -> Domain ControlerInfo:http://wiki.alfresco.com/wiki/Configuring_the_CIFS_and_web_servers_for_Kerberos/AD_integrationhttp://wiki.alfresco.com/wiki/Enterprise_Security_and_Authentication_Configurationhttp://java.sun.com/javase/6/docs/technotes/guides/security/jaas/tutorials/GeneralAcnOnly.htmlAnd many posts in forums in this one, many from belmeki…No luck.Take the easy point first.in http://wiki.alfresco.com/wiki/Enterprise_Security_and_Authentication_Configurationare told that allowing kerberos is as easy as modify 2 files:jaas-authentication-context.xmljava.securityjava.security.configwell… it didnt work.Here's jaas:<?xml version='1.0' encoding='UTF-8'?>
<beans>
<!– The authentication component. –>
<!– Jass authentication - most of the config goes somewhere else –>
<bean id="authenticationComponent"
class="org.alfresco.repo.security.authentication.jaas.JAASAuthenticationComponent">
<property name="realm">
<value>REALM</value>
</property>
<property name="jaasConfigEntryName">
<value>Alfresco</value>
</property>
</bean>
<!– DAO that rejects changes - JAAS is read only at the moment. –>
<!– It does allow users to be deleted with out warnings from the UI. –>
<!– The user is still present in JAAS, only the personal information is removed from alfresco. –>
<bean name="authenticationDao" class="org.alfresco.repo.security.authentication.DefaultMutableAuthenticationDao" >
<property name="allowDeleteUser">
<value>true</value>
</property>
</bean>
</beans>
Here's the line of java.securitylogin.config.url.1=file:C:/Program Files/Java/jdk1.6.0_07/jre/lib/security/java.login.config
and java.security.configAlfresco {
com.sun.security.auth.module.Krb5LoginModule sufficient;
com.sun.net.ssl.client {
other {
};And here's the horrible error (that i dont fully understand):17:43:07,014 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] Schema managed by database dialect org.alfresco.repo.domain.hibernate.dialect.AlfrescoSQLServerDialect.
17:43:10,810 INFO [org.alfresco.repo.domain.schema.SchemaBootstrap] No changes were made to the schema.
17:43:14,482 INFO [org.alfresco.repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: \\172.16.1.103\alfresco$\alf_data
17:43:14,529 INFO [org.alfresco.repo.admin.patch.PatchExecuter] Comprobando si hay parches para aplicar …
17:43:15,092 INFO [org.alfresco.repo.module.ModuleServiceImpl] Found 0 module(s).
17:43:15,295 ERROR [org.alfresco.smb.protocol.auth] No valid CIFS authentication combination available
17:43:15,295 ERROR [org.alfresco.smb.protocol.auth] Either enable Kerberos support or use an authentication component that supports MD4 hashed passwords
17:43:15,310 ERROR [org.alfresco.smb.protocol] CIFS server configuration error, Invalid CIFS authenticator configuration
org.alfresco.error.AlfrescoRuntimeException: Invalid CIFS authenticator configuration
at org.alfresco.filesys.server.auth.EnterpriseCifsAuthenticator.initialize(EnterpriseCifsAuthenticator.java:378)Anyone can give a hand ?Really angry about this one…
