I run test SimpleSimulationRunTest.java with small changes in its PlaybackProcessStartTest.testUserTask.bpmn20.xml file with user task to service task. I got null task object in record() method, i went through the code but didnt find any clue. Even I read crystal ball getting started from github but thats not a good help.
Any help is highly appreciated.
Regards
Sadia Sher
