<bean id="dataSource" class="org.apache.tomcat.jdbc.pool.DataSource" destroy-method="close" p:name="jdbc/FDDataSource" p:jmxEnabled="true" p:driverClassName="${jdbc.driverClassName}" p:url="${jdbc.url}" p:defaultTransactionIsolation="2" p:username="${jdbc.username}" p:password="${jdbc.password}" p:initialSize="25" p:minIdle="25" p:maxIdle="50" p:maxActive="200" p:maxWait="15000" p:logAbandoned="true" p:suspectTimeout="60" p:timeBetweenEvictionRunsMillis="30000" p:minEvictableIdleTimeMillis="60000" p:testOnBorrow="true" p:validationQuery="SELECT 1" p:validationInterval="15000" p:jdbcInterceptors="org.apache.tomcat.jdbc.pool.interceptor.ResetAbandonedTimer" /> <bean id="transactionManager" class="org.springframework.orm.jpa.JpaTransactionManager" p:entityManagerFactory-ref="entityManagerFactory" /> <!– JPA EntityManagerFactory –> <bean id="entityManagerFactory" class="org.springframework.orm.jpa.LocalContainerEntityManagerFactoryBean"> <property name="dataSource" ref="dataSource" /> <property name="jpaVendorAdapter"> <bean class="org.springframework.orm.jpa.vendor.HibernateJpaVendorAdapter"> <property name="showSql" value="${jpa.showSql}" /> <property name="database" value="${jpa.database}" /> </bean> </property> <property name="jpaDialect"> <bean class="org.springframework.orm.jpa.vendor.HibernateJpaDialect" /> </property> <property name="jpaPropertyMap"> <map> <!– Database Configuration –> <entry key="hibernate.dialect" value="org.hibernate.dialect.MySQLInnoDBDialect" /> <entry key="hibernate.hbm2ddl.auto" value="${hibernate.hbm2ddl.auto}" /> <entry key="hibernate.format_sql" value="false" /> <entry key="hibernate.use_sql_comments" value="true" /> <entry key="hibernate.ejb.metamodel.generation" value="disabled" /> <entry key="hibernate.default_batch_fetch_size" value="50" /> <entry key="hibernate.order_updates" value="true" /> <!– READ_COMMITTED –> <entry key="hibernate.connection.isolation" value="2" /> <!– Cache Configuration –> <entry key="hibernate.cache.use_query_cache" value="false" /> <entry key="hibernate.cache.use_second_level_cache" value="false" /> <!– Transaction Management –> <entry key="hibernate.current_session_context_class" value="org.springframework.orm.hibernate3.SpringSessionContext" /> </map> </property> <!– Custom implementation to enrich the PersistenceUnitInfo read from the persistence.xml JPA configuration file with the JTA datasource. specifying the JTA datasource directly in the Spring configuration file has the advantage that we can use a direct reference to the datasource instead of using a JNDI name as requied by the jta-data-source setting in the persistence.xml file –> <property name="persistenceUnitPostProcessors"> <bean class="com.fd.service.jta.JtaPersistenceUnitPostProcessor"> <property name="jtaDataSource" ref="dataSource" /> </bean> </property> <property name="loadTimeWeaver"> <bean class="org.springframework.instrument.classloading.ReflectiveLoadTimeWeaver" /> </property> </bean> <bean id="sessionFactory" factory-bean="entityManagerFactory" factory-method="getSessionFactory" /> <context:annotation-config transaction-manager="transactionManager" /> <!– Instruct Spring to perform declarative transaction management automatically on annotated classes. –> <tx:annotation-driven mode="aspectj" transaction-manager="transactionManager" /> <!– Instruct Spring to retrieve and apply @AspectJ aspects which are defined as beans in this context (such as the CallMonitoringAspect below). –> <aop:aspectj-autoproxy /> <!– Post-processor to perform exception translation on @Repository classes (from native exceptions such as JPA PersistenceExceptions to Spring's DataAccessException hierarchy). –> <bean class="org.springframework.dao.annotation.PersistenceExceptionTranslationPostProcessor" /> <!– ~~~~~~~~~~~~~~~~~~ ACTIVITI BPM ~~~~~~~~~~~~~~~~~~ –> <bean id="activitiProcessEngineConfiguration" class="org.activiti.spring.SpringProcessEngineConfiguration"> <property name="dataSource" ref="dataSource" /> <property name="transactionManager" ref="transactionManager" /> <property name="databaseSchemaUpdate" value="false" /> <property name="jobExecutorActivate" value="false" /> <!– Do not uncomment or process definitions will auto-deploy upon server startup in prod. –> <!– <property name="deploymentResources" value="classpath*:/com/fd/bpm/*.bpmn20.xml" /> –> <property name="history" value="audit" /> </bean> <bean id="activitiProcessEngine" class="org.activiti.spring.ProcessEngineFactoryBean"> <property name="processEngineConfiguration" ref="activitiProcessEngineConfiguration" /> </bean> <bean id="activitiRepositoryService" factory-bean="activitiProcessEngine" factory-method="getRepositoryService" /> <bean id="activitiRuntimeService" factory-bean="activitiProcessEngine" factory-method="getRuntimeService" /> <bean id="activitiTaskService" factory-bean="activitiProcessEngine" factory-method="getTaskService" /> <bean id="activitiHistoryService" factory-bean="activitiProcessEngine" factory-method="getHistoryService" /> <bean id="activitiManagementService" factory-bean="activitiProcessEngine" factory-method="getManagementService" /> <bean id="activitiIdentityService" factory-bean="activitiProcessEngine" factory-method="getIdentityService" /> <bean id="activitiFormService" factory-bean="activitiProcessEngine" factory-method="getFormService" />
