Hi everyone,
I have problems with Solr, it is not working.
On dashboard view, an error is displayed in the document dashlet "Error loading items".
And searches don´t produce any result.
I am working with this version:
- Alfresco Platform: 5.2.g
-Alfresco Share: 5.2.f
I tried to perform a full reindex with solr following these steps:
https://docs.alfresco.com/5.0/tasks/solr-reindex.html
But it doesn't work, I noticed that after starting up the application server the directories:
<ALFRESCO_HOME>/alf_data/solr4/model
<ALFRESCO_HOME>/alf_data/solr4/content
Where still empty.
This is the log of solr I got:
solr.log
2020-07-30 01:49:40,668 ERROR [org.alfresco.solr.tracker.AbstractTracker] Model tracking failed
java.net.ConnectException: Connection refused (Connection refused)
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:350)
at java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:206)
at java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:188)
at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
at java.net.Socket.connect(Socket.java:589)
at sun.security.ssl.SSLSocketImpl.connect(SSLSocketImpl.java:668)
at sun.security.ssl.SSLSocketImpl.<init>(SSLSocketImpl.java:472)
at sun.security.ssl.SSLSocketFactoryImpl.createSocket(SSLSocketFactoryImpl.java:153)
at org.alfresco.encryption.ssl.AuthSSLProtocolSocketFactory.createSocket(AuthSSLProtocolSocketFactory.java:168)
at org.apache.commons.httpclient.HttpConnection.open(HttpConnection.java:707)
at org.apache.commons.httpclient.MultiThreadedHttpConnectionManager$HttpConnectionAdapter.open(MultiThreadedHttpConnectionManager.java:1361)
at org.apache.commons.httpclient.HttpMethodDirector.executeWithRetry(HttpMethodDirector.java:387)
at org.apache.commons.httpclient.HttpMethodDirector.executeMethod(HttpMethodDirector.java:171)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:397)
at org.apache.commons.httpclient.HttpClient.executeMethod(HttpClient.java:323)
at org.alfresco.httpclient.AbstractHttpClient.executeMethod(AbstractHttpClient.java:135)
at org.alfresco.httpclient.AbstractHttpClient.sendRemoteRequest(AbstractHttpClient.java:111)
at org.alfresco.httpclient.HttpClientFactory$HttpsClient.sendRequest(HttpClientFactory.java:408)
at org.alfresco.solr.client.SOLRAPIClient.getModelsDiff(SOLRAPIClient.java:1178)
at org.alfresco.solr.tracker.ModelTracker.trackModelsImpl(ModelTracker.java:256)
at org.alfresco.solr.tracker.ModelTracker.trackModels(ModelTracker.java:214)
at org.alfresco.solr.tracker.ModelTracker.ensureFirstModelSync(ModelTracker.java:236)
at org.alfresco.solr.tracker.CoreWatcherJob.registerForCore(CoreWatcherJob.java:145)
at org.alfresco.solr.tracker.CoreWatcherJob.execute(CoreWatcherJob.java:82)
at org.quartz.core.JobRunShell.run(JobRunShell.java:216 share.log
2020-07-30 01:49:41,494 WARN [org.springframework.extensions.surf.persister.AbstractStoreObjectPersister] [http-apr-80-exec-1] Failure to load model object for path: template-instances/.customise-user-dashboard.xml.swp
org.springframework.extensions.surf.exception.ModelObjectPersisterException: Failure to load model object for path: template-instances/.customise-user-dashboard.xml.swp
at org.springframework.extensions.surf.persister.ReadOnlyStoreObjectPersister.getObjectByPath(ReadOnlyStoreObjectPersister.java:628)
at org.springframework.extensions.surf.persister.AbstractStoreObjectPersister.getObjectsFromPaths(AbstractStoreObjectPersister.java:374)
at org.springframework.extensions.surf.persister.AbstractStoreObjectPersister.getAllObjects(AbstractStoreObjectPersister.java:311)
at org.springframework.extensions.surf.persister.MultiObjectPersister.getAllObjects(MultiObjectPersister.java:399)
at org.springframework.extensions.surf.ObjectPersistenceService.getAllObjects(ObjectPersistenceService.java:452)
at org.springframework.extensions.surf.ModelObjectService.getAllObjects(ModelObjectService.java:616)
at org.springframework.extensions.surf.ModuleDeploymentService.getExtensionModules(ModuleDeploymentService.java:368)
at org.springframework.extensions.surf.ModuleDeploymentService.getAllConfiguredExtensionModules(ModuleDeploymentService.java:353)
at org.springframework.extensions.surf.ModuleDeploymentService.getDeployedModules(ModuleDeploymentService.java:471)
at org.springframework.extensions.surf.extensibility.impl.BasicExtensibilityModuleHandler.evaluateModules(BasicExtensibilityModuleHandler.java:191)
at org.springframework.extensions.surf.support.AbstractRequestContext.getEvaluatedModules(AbstractRequestContext.java:1008)
at org.springframework.extensions.surf.support.AbstractRequestContext.getExtendingModuleFiles(AbstractRequestContext.java:1221)
at org.springframework.extensions.webscripts.WebTemplateProcessor.executeScriptBodyExtensions(WebTemplateProcessor.java:237)
at org.springframework.extensions.webscripts.WebTemplateProcessor.executeBody(WebTemplateProcessor.java:348)
at org.springframework.extensions.surf.render.AbstractProcessor.execute(AbstractProcessor.java:58)
at org.springframework.extensions.surf.render.RenderService.processTemplate(RenderService.java:724)
at org.springframework.extensions.surf.render.bean.TemplateInstanceRenderer.calculateComponentDependencies(TemplateInstanceRenderer.java:77)
at org.springframework.extensions.surf.render.bean.TemplateInstanceRenderer.body(TemplateInstanceRenderer.java:136)
at org.springframework.extensions.surf.render.AbstractRenderer.render(AbstractRenderer.java:78)
at org.springframework.extensions.surf.render.bean.PageRenderer.body(PageRenderer.java:86)
at org.springframework.extensions.surf.render.RenderService.renderPage(RenderService.java:770)
at org.springframework.extensions.surf.mvc.PageView.dispatchPage(PageView.java:412)
at org.springframework.extensions.surf.mvc.PageView.renderView(PageView.java:251)
at org.springframework.extensions.surf.mvc.AbstractWebFrameworkView.renderMergedOutputModel(AbstractWebFrameworkView.java:321)
at org.springframework.web.servlet.view.AbstractView.render(AbstractView.java:264)
at org.springframework.web.servlet.DispatcherServlet.render(DispatcherServlet.java:1216)
at org.springframework.web.servlet.DispatcherServlet.processDispatchResult(DispatcherServlet.java:1001)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:945)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:867)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:951)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:842)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:624)
at org.springframework.web.servlet.FrameworkServlet.service(FrameworkServlet.java:827)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:731)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:303)
at org.apache.tomcat.websocket.server.WsFilter.doFilter(WsFilter.java:52)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:241)
at org.springframework.extensions.webscripts.servlet.SecurityHeadersFilter.doFilter(SecurityHeadersFilter.java:177)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:208) at org.springframework.extensions.webscripts.servlet.CSRFFilter.doFilter(CSRFFilter.java:322)
at org.alfresco.web.site.servlet.SSOAuthenticationFilter.doFilter(SSOAuthenticationFilter.java:474)
at org.alfresco.web.site.servlet.SSOAuthenticationFilter.doFilter(SSOAuthenticationFilter.java:443)
at org.springframework.extensions.webscripts.servlet.BeanProxyFilter.doFilter(BeanProxyFilter.java:80)
at org.alfresco.web.site.servlet.MTAuthenticationFilter.doFilter(MTAuthenticationFilter.java:81)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:218)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:110)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:506)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:169)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:103)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:962)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:445)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1115)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:637)
at org.apache.tomcat.util.net.AprEndpoint$SocketWithOptionsProcessor.run(AprEndpoint.java:2486)
at java.lang.Thread.run(Thread.java:748)
Caused by: org.dom4j.DocumentException: Error on line 1 of document : Content is not allowed in prolog. Nested exception: Content is not allowed in prolog.
at org.dom4j.io.SAXReader.read(SAXReader.java:482)
at org.dom4j.DocumentHelper.parseText(DocumentHelper.java:278)Thank you all.
