alfresco-labs:/opt/alfresco# ./Alfresco-Labs-3b-Linux-x86-Install Alfresco-Labs-3b-Linux-x86-Install: dl-open.c:438: dl_open_worker: Assertion `imap->l_type == lt_loaded' failed.Aborted
debian:/vol1/tmp/Alfresco# uname -a Linux debian 2.6.18-4-k7 #1 SMP Mon Mar 26 17:57:15 UTC 2007 i686 GNU/Linux debian:/vol1/tmp/Alfresco# java -version java version "1.6.0_07" Java(TM) SE Runtime Environment (build 1.6.0_07-b06) Java HotSpot(TM) Client VM (build 10.0-b23, mixed mode, sharing) debian:/vol1/tmp/Alfresco# chmod +x Alfresco-Labs-3b-Linux-x86-Install debian:/vol1/tmp/Alfresco# ./Alfresco-Labs-3b-Linux-x86-Install Alfresco-Labs-3b-Linux-x86-Install: dl-open.c:438: dl_open_worker: Assertion `imap->l_type == lt_loaded' failed. Aborted debian:/vol1/tmp/Alfresco#
Roel Dircks, The Alfresco install has Tomcat as a webserver so you do not need apache.You do need JAVA.JAVA is used for running alfresco, not for the install.The wiki page you referenced does not provide accurate steps for a linux install. Please refer to my wiki page http://wiki.alfresco.com/wiki/Installing_Labs_3_on_Linux_with_command_line_interface Please let me know if you have better success.Be sure to try what BELMEKKI suggested:chmod +x Alfresco-Labs-3b-Linux-x86-Install , then retry to it.Dimic there is no dependency for php or imap in that install package, so the error is misleading.Sorry I do not have a direct answer, just some guidance. Cheers
Update your java version ( JRE version ) to the latest one.It will solve your problem.
