Hi,I have just installed Alfresco Labs 3 stable for Windows and I use Tomcat server. The installation works fine, but :- I can't access to Alfresco Explorer : I have Http Status 404. description The requested resource () is not available. Apache Tomcat/6.0.18- I can't log in Alfresco Share : "The remote server may be unavailable or your authentication details have not been recognized."I turned off my firewall but it still doesn't work. Here is my alfresco.log file :20:20:46,437 WARN [org.springframework.jmx.support.JmxUtils] Found more than one MBeanServer instance. Returning first from list.
20:20:50,959 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
20:21:06,667 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'org.apache.cxf.wsdl.WSDLManager' defined in class path resource [META-INF/cxf/cxf.xml]: Instantiation of bean failed; nested exception is org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.apache.cxf.wsdl11.WSDLManagerImpl]: Constructor threw exception; nested exception is java.lang.LinkageError: JAXB 2.0 API is being loaded from the bootstrap classloader, but this RI (from jar:file:/C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/lib/jaxb-impl-2.1.7.jar!/com/sun/xml/bind/v2/model/impl/ModelBuilder.class) needs 2.1 API. Use the endorsed directory mechanism to place jaxb-api.jar in the bootstrap classloader. (See http://java.sun.com/j2se/1.5.0/docs/guide/standards/)
Caused by: org.springframework.beans.BeanInstantiationException: Could not instantiate bean class [org.apache.cxf.wsdl11.WSDLManagerImpl]: Constructor threw exception; nested exception is java.lang.LinkageError: JAXB 2.0 API is being loaded from the bootstrap classloader, but this RI (from jar:file:/C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/lib/jaxb-impl-2.1.7.jar!/com/sun/xml/bind/v2/model/impl/ModelBuilder.class) needs 2.1 API. Use the endorsed directory mechanism to place jaxb-api.jar in the bootstrap classloader. (See http://java.sun.com/j2se/1.5.0/docs/guide/standards/)
Caused by: java.lang.LinkageError: JAXB 2.0 API is being loaded from the bootstrap classloader, but this RI (from jar:file:/C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/lib/jaxb-impl-2.1.7.jar!/com/sun/xml/bind/v2/model/impl/ModelBuilder.class) needs 2.1 API. Use the endorsed directory mechanism to place jaxb-api.jar in the bootstrap classloader. (See http://java.sun.com/j2se/1.5.0/docs/guide/standards/)
at com.sun.xml.bind.v2.model.impl.ModelBuilder.<clinit>(ModelBuilder.java:173)
at com.sun.xml.bind.v2.runtime.JAXBContextImpl.getTypeInfoSet(JAXBContextImpl.java:422)
at com.sun.xml.bind.v2.runtime.JAXBContextImpl.<init>(JAXBContextImpl.java:286)
at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:139)
at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:117)
at com.sun.xml.bind.v2.ContextFactory.createContext(ContextFactory.java:188)
at javax.xml.bind.ContextFinder.newInstance(ContextFinder.java:132)
at javax.xml.bind.ContextFinder.find(ContextFinder.java:286)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:372)
at javax.xml.bind.JAXBContext.newInstance(JAXBContext.java:337)
at org.apache.cxf.wsdl.JAXBExtensionHelper.createJAXBContext(JAXBExtensionHelper.java:183)
at org.apache.cxf.wsdl.JAXBExtensionHelper.getJAXBContext(JAXBExtensionHelper.java:170)
at org.apache.cxf.wsdl.JAXBExtensionHelper.addExtensions(JAXBExtensionHelper.java:155)
at org.apache.cxf.wsdl.JAXBExtensionHelper.addExtensions(JAXBExtensionHelper.java:86)
at org.apache.cxf.wsdl11.WSDLManagerImpl.registerInitialExtensions(WSDLManagerImpl.java:241)
at org.apache.cxf.wsdl11.WSDLManagerImpl.registerInitialExtensions(WSDLManagerImpl.java:221)
at org.apache.cxf.wsdl11.WSDLManagerImpl.<init>(WSDLManagerImpl.java:110)
at org.springframework.beans.BeanUtils.instantiateClass(BeanUtils.java:85)
at org.springframework.beans.factory.support.SimpleInstantiationStrategy.instantiate(SimpleInstantiationStrategy.java:61)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.instantiateBean(AbstractAutowireCapableBeanFactory.java:756)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:721)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:384)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:251)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:156)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:248)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:160)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:287)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:352)
at org.springframework.web.context.ContextLoader.createWebApplicationContext(ContextLoader.java:244)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:187)
at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:830)
at org.apache.catalina.startup.HostConfig.deployWARs(HostConfig.java:719)
20:21:26,333 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
20:21:36,382 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
20:21:36,387 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 1560.752ms)
20:22:38,853 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
20:22:38,853 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 62399.504ms)
20:22:39,109 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
22:59:17,287 WARN [org.springframework.jmx.support.JmxUtils] Found more than one MBeanServer instance. Returning first from list.
22:59:22,537 INFO [org.alfresco.config.xml.XMLConfigService$PropertyConfigurer] Loading properties file from class path resource [alfresco/file-servers.properties]
22:59:38,526 ERROR [org.springframework.web.context.ContextLoader] Context initialization failed
22:59:59,292 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
23:00:12,369 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 67 Web Scripts (+0 failed), 71 URLs
23:00:12,377 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised Presentation Web Script Container (in 1631.386ms)
23:01:14,949 INFO [org.alfresco.web.scripts.DeclarativeRegistry] Registered 101 Web Scripts (+0 failed), 105 URLs
23:01:14,949 INFO [org.alfresco.web.scripts.AbstractRuntimeContainer] Initialised WebFramework Web Script Container (in 62484.773ms)
23:01:15,331 INFO [org.alfresco.web.site.FrameworkHelper] Successfully Initialized Web Framework
What can I do ?Thank you in advance for your answers
