i try to use alfresco in the embedded way.
First of all i look at FirstFoundationClient in sdk; i see that it use alfresco embedded sdk project to work; i start it and it work correctly also obtaining at the starting point the application context object from application-context.xml file.
So i try the same operations but not including alfrescoEmbedded sdk project in my library. So i try to obtain ApplicationContext object but i have the following exception:
EXCEPTION:
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'luceneFullTextSearchIndexer' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'indexerAndSearcherFactory' while setting bean property 'indexerAndSearcherFactory'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexerAndSearcherFactory' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'admLuceneIndexerAndSearcherFactory' while setting bean property 'defaultBinding'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'admLuceneIndexerAndSearcherFactory' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'mlAwareNodeService' while setting bean property 'nodeService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mlAwareNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeService' while setting bean property 'defaultBinding'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeServiceImpl' while setting bean property 'target'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dictionaryService' while setting bean property 'dictionaryService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'dictionaryDAO' while setting bean property 'dictionaryDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'indexerAndSearcherFactory' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'admLuceneIndexerAndSearcherFactory' while setting bean property 'defaultBinding'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'admLuceneIndexerAndSearcherFactory' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'mlAwareNodeService' while setting bean property 'nodeService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mlAwareNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeService' while setting bean property 'defaultBinding'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeServiceImpl' while setting bean property 'target'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dictionaryService' while setting bean property 'dictionaryService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'dictionaryDAO' while setting bean property 'dictionaryDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'admLuceneIndexerAndSearcherFactory' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'mlAwareNodeService' while setting bean property 'nodeService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mlAwareNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeService' while setting bean property 'defaultBinding'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeServiceImpl' while setting bean property 'target'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dictionaryService' while setting bean property 'dictionaryService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'dictionaryDAO' while setting bean property 'dictionaryDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'mlAwareNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeService' while setting bean property 'defaultBinding'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeServiceImpl' while setting bean property 'target'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dictionaryService' while setting bean property 'dictionaryService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'dictionaryDAO' while setting bean property 'dictionaryDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeService' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dbNodeServiceImpl' while setting bean property 'target'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dictionaryService' while setting bean property 'dictionaryService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'dictionaryDAO' while setting bean property 'dictionaryDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dbNodeServiceImpl' defined in class path resource [alfresco/node-services-context.xml]: Cannot resolve reference to bean 'dictionaryService' while setting bean property 'dictionaryService'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'dictionaryDAO' while setting bean property 'dictionaryDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryBootstrap' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'dictionaryDAO' while setting bean property 'dictionaryDAO'; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'dictionaryDAO' defined in class path resource [alfresco/core-services-context.xml]: Cannot resolve reference to bean 'namespaceDAO' while setting constructor argument with index 0; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'namespaceDAO' defined in class path resource [alfresco/core-services-context.xml]: Error setting property values; nested exception is org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
Caused by: org.springframework.beans.NotWritablePropertyException: Invalid property 'tenantService' of bean class [org.alfresco.repo.dictionary.NamespaceDAOImpl]: Bean property 'tenantService' is not writable or has an invalid setter method. Does the parameter type of the setter match the return type of the getter?
at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:748)
at org.springframework.beans.BeanWrapperImpl.setPropertyValue(BeanWrapperImpl.java:606)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValue(AbstractPropertyAccessor.java:49)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:74)
at org.springframework.beans.AbstractPropertyAccessor.setPropertyValues(AbstractPropertyAccessor.java:57)
at org.springframework.beans.factory.support.AbstractBeanFactory.applyPropertyValues(AbstractBeanFactory.java:840)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1026)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:809)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:425)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:250)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:141)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:247)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:161)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:245)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:124)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:316)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:91)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:745)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:683)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:388)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1019)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:341)
at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:642)
at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:419)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:328)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:92)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:77)
at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:68)
at it.saga.egov.esi.cms.utility.TestEmbedded.main(TestEmbedded.java:22)
END EXCEPTION
I'm using alfresco community 2.1.0 tomcat boundled; when i invoke the method "ApplicationContext ctx = new ClassPathXmlApplicationContext("alfresco/application-context.xml")", i tried to set also the absolute path to application-context.xml file that in my case is "C:/Alfresco/tomcat/webapps/alfresco/WEB-INF/classes/alfresco/application-context.xml" AND IN THIS CASE I OBTAIN A FileNotFoundException.
I'VE READ IN OTHER TOPICS THAT USING WEBAPPS LIKE TOMCAT THE METHOD ApplicationContext ctx = new ClassPathXmlApplicationContext("alfresco/application-context.xml") DOESN'T WORK CORRECTLY ALSO USING ABSOLUTE PATH AS I DID.
CAN SOMEONE HELP ME TO RESOLVE THIS PROBLEM?
