I want to design a workflow base web application and the UI will be designed using spring mvc frame work and activiti engine as a backed.
I have few doubts.
1. Will the activiti process engine start from the spring context file or we should start it using a controller with load on start up process.
2. how will be the process get deployed ? Do we need to invoke the rest api for deployment of the bar or process xml files. If yes can you please share the rest api method which will be used.
3. If a custom form is used for a user task how will the form fields be mapped to process variables and how will it interact with the activiti tables at run time.
Please suggest.
Thanks in advance.
