MySQL started at port 3306
Installing and Configuring Alfresco > Configuring Alfresco > Configuring databases > Configuring a MySQL database > Creating the Alfresco database
mysql -u root -p
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock'
/alfresco/mysql/tmp/
1. Je vais à l'emplacement /alfresco avec le terminal et je fais la commande ./alfresco.sh stop2. Je vais à l'emplacement /etc/rc.d/init.d/ et je fais ./mysqld start(À ce point-ci, j'ai essayé l'étape suivante sans redémarrer Tomcat puisque le problème concernait MySQL seulement à première vue, mais j'ai essayé ensuite après l'avoir redémarré à partir de /alfresco en faisant ./alfresco.sh start)3. Je tente de nouveau mysql -u root -p
ERROR 1045 (28000): Access denied for user 'root'@'localhost'
ps -ef | grep mysqld
root 1993 1 0 18:37 ? 00:00:00 /bin/sh /usr/bin/mysqld_safe –datadir=/opt/mysql-data –socket=/var/lib/mysql/mysql.sock –pid-file=/var/run/mysqld/mysqld.pid –basedir=/usr –user=mysql mysql 2130 1993 0 18:37 ? 00:00:22 /usr/libexec/mysqld –basedir=/usr –datadir=/opt/mysql-data –user=mysql –log-error=/var/log/mysqld.log –pid-file=/var/run/mysqld/mysqld.pid –socket=/var/lib/mysql/mysql.sock romain 6241 3674 0 20:03 pts/2 00:00:00 grep –color=auto mysqld
mysql -u root -p –socket=/alfresco/mysql/tmp/mysql.sock
mysql -u root -p –defaults-file=/alfresco/mysql/my.cnf
ln -s /alfresco/mysql/my.cnf /etc/my.cnf
mysql -u root -p
mysql: unknown variable 'defaults-file=/alfresco/mysql/my.cnf'
ln: '/etc/my.cnf': fichier inexistant.
mysql –defaults-file=/alfresco/mysql/my.cnf -u root -p
The syntax for creating symbolic links is as follows: ln -s sourcefile1 [ sourcefile2 … ] targetIf target already exists and is not a directory, an error is returned.
dir.root=/opt/alfresco/alf_data web.application.context.url=http://localhost:8080/alfresco ### database connection properties ### db.driver=org.gjt.mm.mysql.Driver db.username=alfresco db.password=alfresco db.name=alfresco db.url=jdbc:mysql://localhost:3306/${db.name}?useUnicode=true&characterEncoding=utf8
mysql -u root -p
ERROR 2002 (HY000): Can't connect to local MySQL server through socket '/var/run/mysqld/mysqld.sock' (2)
root 16658 1 0 09:05 ? 00:00:00 /bin/sh /opt/alfresco/mysql/bin/mysqld_safe –defaults-file=/opt/alfresco/mysql/my.cnf –port=3306 –socket=/opt/alfresco/mysql/tmp/mysql.sock –old-passwords –datadir=/opt/alfresco/mysql/data –log-error=/opt/alfresco/mysql/data/mysqld.log –pid-file=/opt/alfresco/mysql/data/ubuntu-virtual-machine.pid –lower-case-table-names=1 –default-table-type=InnoDB mysql 16772 16658 0 09:05 ? 00:00:15 /opt/alfresco/mysql/bin/mysqld.bin –defaults-file=/opt/alfresco/mysql/my.cnf –basedir=/opt/alfresco/mysql –datadir=/opt/alfresco/mysql/data –user=mysql –old-passwords –lower-case-table-names=1 –default-table-type=InnoDB –log-error=/opt/alfresco/mysql/data/mysqld.log –pid-file=/opt/alfresco/mysql/data/ubuntu-virtual-machine.pid –socket=/opt/alfresco/mysql/tmp/mysql.sock –port=3306 root 17581 17384 0 16:43 pts/0 00:00:00 grep –color=auto mysqld
cd /etc/mysql/ ls mv my.cnf my.cnf.old ln -s /opt/alfresco/mysql/my.cnf my.cnf
