Hy, I have a problem with runas when it's used in a WF JScript.I'm running as admin, It give me permissions to create a file without problems, but when i'm trying to modify it, Alfresco returns me this error:15:11:28,156 ERROR [org.alfresco.repo.transaction.AlfrescoTransactionSupport] After completion (rolled-back) listener exception:
listener: org.alfresco.repo.workflow.jbpm.JBPMTransactionTemplate@4153dad8
org.jbpm.JbpmException: closed JbpmContext more then once… check your try-finally's around JbpmContexts blocks
at org.jbpm.JbpmConfiguration.popJbpmContext(JbpmConfiguration.java:551)
at org.jbpm.JbpmConfiguration.jbpmContextClosed(JbpmConfiguration.java:567)
at org.jbpm.JbpmContext.close(JbpmContext.java:144)
at org.springmodules.workflow.jbpm31.JbpmTemplate.releaseContext(JbpmTemplate.java:111)
at org.alfresco.repo.workflow.jbpm.JBPMTransactionTemplate.afterRollback(JBPMTransactionTemplate.java:195)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.afterCompletion(AlfrescoTransactionSupport.java:724)
at org.springframework.transaction.support.TransactionSynchronizationUtils.invokeAfterCompletion(TransactionSynchronizationUtils.java:133)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.invokeAfterCompletion(AbstractPlatformTransactionManager.java:890)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.triggerAfterCompletion(AbstractPlatformTransactionManager.java:865)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.doRollbackOnCommitException(AbstractPlatformTransactionManager.java:808)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:682)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.commit(AbstractPlatformTransactionManager.java:624)
at org.springframework.transaction.interceptor.TransactionAspectSupport.commitTransactionAfterReturning(TransactionAspectSupport.java:307)
at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:431)
at org.alfresco.web.bean.workflow.ManageTaskDialog.transition(ManageTaskDialog.java:395)
at org.apache.myfaces.el.MethodBindingImpl.invoke(MethodBindingImpl.java:132)
at org.apache.myfaces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:61)
at javax.faces.component.UICommand.broadcast(UICommand.java:109)
at javax.faces.component.UIViewRoot._broadcastForPhase(UIViewRoot.java:97)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:171)
at org.apache.myfaces.lifecycle.InvokeApplicationExecutor.execute(InvokeApplicationExecutor.java:32)
at org.apache.myfaces.lifecycle.LifecycleImpl.executePhase(LifecycleImpl.java:95)
at org.apache.myfaces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:70)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:139)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:269)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:188)
at org.alfresco.web.app.servlet.AuthenticationFilter.doFilter(AuthenticationFilter.java:81)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:215)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:210)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:174)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:117)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:108)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:151)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:870)
at org.apache.coyote.http11.Http11BaseProtocol$Http11ConnectionHandler.processConnection(Http11BaseProtocol.java:665)
at org.apache.tomcat.util.net.PoolTcpEndpoint.processSocket(PoolTcpEndpoint.java:528)
at org.apache.tomcat.util.net.LeaderFollowerWorkerThread.runIt(LeaderFollowerWorkerThread.java:81)
at org.apache.tomcat.util.threads.ThreadPool$ControlRunnable.run(ThreadPool.java:685)
15:11:28,171 ERROR [org.alfresco.web.ui.common.Utils] A system error happened during the operation: Transaction didn't commit: Failed to execute transaction-level behaviour public abstract void org.alfresco.repo.content.ContentServicePolicies$OnContentUpdatePolicy.onContentUpdate(org.alfresco.service.cmr.repository.NodeRef,boolean) in transaction 5c0e8dc2-0fce-11dd-841b-db99deb4b60b
javax.transaction.RollbackException: Transaction didn't commit: Failed to execute transaction-level behaviour public abstract void org.alfresco.repo.content.ContentServicePolicies$OnContentUpdatePolicy.onContentUpdate(org.alfresco.service.cmr.repository.NodeRef,boolean) in transaction 5c0e8dc2-0fce-11dd-841b-db99deb4b60b
at org.alfresco.util.transaction.SpringAwareUserTransaction.commit(SpringAwareUserTransaction.java:441)
Caused by: org.alfresco.error.AlfrescoRuntimeException: Failed to execute transaction-level behaviour public abstract void org.alfresco.repo.content.ContentServicePolicies$OnContentUpdatePolicy.onContentUpdate(org.alfresco.service.cmr.repository.NodeRef,boolean) in transaction 5c0e8dc2-0fce-11dd-841b-db99deb4b60b
at org.alfresco.repo.policy.TransactionBehaviourQueue.execute(TransactionBehaviourQueue.java:201)
at org.alfresco.repo.policy.TransactionBehaviourQueue.beforeCommit(TransactionBehaviourQueue.java:133)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.doBeforeCommit(AlfrescoTransactionSupport.java:638)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.doBeforeCommit(AlfrescoTransactionSupport.java:620)
at org.alfresco.repo.transaction.AlfrescoTransactionSupport$TransactionSynchronizationImpl.beforeCommit(AlfrescoTransactionSupport.java:592)
at org.springframework.transaction.support.TransactionSynchronizationUtils.triggerBeforeCommit(TransactionSynchronizationUtils.java:48)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.triggerBeforeCommit(AbstractPlatformTransactionManager.java:821)
at org.springframework.transaction.support.AbstractPlatformTransactionManager.processCommit(AbstractPlatformTransactionManager.java:637)
… 31 more
Caused by: org.alfresco.repo.security.permissions.AccessDeniedException: Access Denied. You do not have the appropriate permissions to perform this operation.
at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:53)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:176)
at org.alfresco.repo.audit.AuditComponentImpl.audit(AuditComponentImpl.java:245)
at org.alfresco.repo.audit.AuditMethodInterceptor.invoke(AuditMethodInterceptor.java:69)
at org.springframework.transaction.interceptor.TransactionInterceptor.invoke(TransactionInterceptor.java:107)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:210)
at $Proxy3.hasAspect(Unknown Source)
at org.alfresco.repo.version.VersionServiceImpl.createVersion(VersionServiceImpl.java:300)
at org.alfresco.repo.version.VersionServiceImpl.createVersion(VersionServiceImpl.java:183)
at org.alfresco.repo.version.VersionableAspect.onContentUpdate(VersionableAspect.java:251)
at sun.reflect.GeneratedMethodAccessor4977.invoke(Unknown Source)
at org.alfresco.repo.policy.JavaBehaviour$JavaMethodInvocationHandler.invoke(JavaBehaviour.java:179)
at $Proxy36.onContentUpdate(Unknown Source)
at sun.reflect.GeneratedMethodAccessor702.invoke(Unknown Source)
at org.alfresco.repo.policy.TransactionBehaviourQueue.execute(TransactionBehaviourQueue.java:189)
… 41 more
Caused by: net.sf.acegisecurity.AccessDeniedException: Access is denied.
at net.sf.acegisecurity.vote.AffirmativeBased.decide(AffirmativeBased.java:86)
at net.sf.acegisecurity.intercept.AbstractSecurityInterceptor.beforeInvocation(AbstractSecurityInterceptor.java:394)
at org.alfresco.repo.security.permissions.impl.ExceptionTranslatorMethodInterceptor.invoke(ExceptionTranslatorMethodInterceptor.java:49)
… 61 more
15:11:28,250 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco].[jsp]] El Servlet.service() para servlet jsp lanzó una excepción
at org.alfresco.repo.workflow.jbpm.JBPMEngine.createWorkflowNode(JBPMEngine.java:2667)
at org.alfresco.repo.workflow.jbpm.JBPMEngine.createWorkflowPath(JBPMEngine.java:2653)
at org.alfresco.repo.workflow.jbpm.JBPMEngine.createWorkflowTask(JBPMEngine.java:2809)
at org.alfresco.repo.workflow.jbpm.JBPMEngine$24.doInJbpm(JBPMEngine.java:1282)
at org.alfresco.repo.workflow.jbpm.JBPMEngine$24.doInJbpm(JBPMEngine.java:1258)
at org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:367)
at org.springframework.orm.hibernate3.HibernateTemplate.execute(HibernateTemplate.java:333)
at org.alfresco.repo.workflow.jbpm.JBPMEngine.queryTasks(JBPMEngine.java:1257)
at org.alfresco.repo.workflow.WorkflowServiceImpl.queryTasks(WorkflowServiceImpl.java:482)
at sun.reflect.GeneratedMethodAccessor1020.invoke(Unknown Source)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:281)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:187)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:154)
at org.alfresco.repo.security.permissions.impl.AlwaysProceedMethodInterceptor.invoke(AlwaysProceedMethodInterceptor.java:40)
at $Proxy41.queryTasks(Unknown Source)
at org.alfresco.web.ui.repo.component.UIWorkflowHistory.encodeBegin(UIWorkflowHistory.java:122)
at javax.faces.webapp.UIComponentTag.encodeBegin(UIComponentTag.java:467)
at javax.faces.webapp.UIComponentTag.doStartTag(UIComponentTag.java:320)
at org.apache.jsp.jsp.workflow.manage_002dtask_002ddialog_jsp._jspx_meth_r_005fworkflowHistory_005f0(manage_002dtask_002ddialog_jsp.java:1708)
at org.apache.jsp.jsp.workflow.manage_002dtask_002ddialog_jsp._jspx_meth_a_005fpanel_005f4(manage_002dtask_002ddialog_jsp.java:1684)
at org.apache.jsp.jsp.workflow.manage_002dtask_002ddialog_jsp._jspx_meth_a_005fpanel_005f3(manage_002dtask_002ddialog_jsp.java:1597)
at org.apache.jsp.jsp.workflow.manage_002dtask_002ddialog_jsp._jspService(manage_002dtask_002ddialog_jsp.java:196)
at org.apache.jasper.runtime.HttpJspBase.service(HttpJspBase.java:98)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
at org.apache.jasper.servlet.JspServletWrapper.service(JspServletWrapper.java:328)
at org.apache.jasper.servlet.JspServlet.serviceJspFile(JspServlet.java:315)
at org.apache.jasper.servlet.JspServlet.service(JspServlet.java:265)
at org.apache.catalina.core.ApplicationDispatcher.invoke(ApplicationDispatcher.java:691)
at org.apache.catalina.core.ApplicationDispatcher.doInclude(ApplicationDispatcher.java:594)
at org.apache.catalina.core.ApplicationDispatcher.include(ApplicationDispatcher.java:505)
at org.apache.jasper.runtime.JspRuntimeLibrary.include(JspRuntimeLibrary.java:965)
at org.apache.jsp.jsp.dialog.container_jsp._jspService(container_jsp.java:613)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:469)
at org.apache.catalina.core.ApplicationDispatcher.doForward(ApplicationDispatcher.java:403)
at org.apache.catalina.core.ApplicationDispatcher.forward(ApplicationDispatcher.java:301)
at org.apache.myfaces.context.servlet.ServletExternalContextImpl.dispatch(ServletExternalContextImpl.java:419)
at org.apache.myfaces.application.jsp.JspViewHandlerImpl.renderView(JspViewHandlerImpl.java:211)
at org.apache.myfaces.lifecycle.RenderResponseExecutor.execute(RenderResponseExecutor.java:41)
at org.apache.myfaces.lifecycle.LifecycleImpl.render(LifecycleImpl.java:132)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:140)
15:11:28,250 ERROR [org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/alfresco].[Faces Servlet]] Servlet.service() para servlet Faces Servlet lanzó excepción
at org.alfresco.web.app.servlet.FacesHelper.getManagedBean(FacesHelper.java:153)
at org.alfresco.web.ui.repo.tag.PageTag.getWindowOnloadCode(PageTag.java:365)
at org.alfresco.web.ui.repo.tag.PageTag.doStartTag(PageTag.java:275)
at org.apache.jsp.jsp.error_jsp._jspService(error_jsp.java:74)
at org.apache.catalina.core.ApplicationDispatcher.processRequest(ApplicationDispatcher.java:471)
at org.apache.catalina.core.StandardHostValve.custom(StandardHostValve.java:364)
at org.apache.catalina.core.StandardHostValve.throwable(StandardHostValve.java:213)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:135)
Also when i check the creator/modifier of file, it shows me admin as creator and the user how running the task as modifier!!!So I think that's a <runas> problem….I hope thath we can find a solution….
