Tested in version 5.13:My BPMN Process (simpleprocess.bpmn):
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
<process id="myProcess" name="My process" isExecutable="true">
<userTask id="usertask1" name="UserTask1"></userTask>
<sequenceFlow id="flow1" sourceRef="startevent1" targetRef="usertask1"></sequenceFlow>
<userTask id="usertask2" name="UserTask2"></userTask>
<sequenceFlow id="flow2" sourceRef="usertask1" targetRef="usertask2"></sequenceFlow>
<sequenceFlow id="flow3" sourceRef="usertask2" targetRef="endevent1"></sequenceFlow>
</process>
</definitions>
My JUnit Test:
public class ProcessTestMyProcess {
private String filename = "simpleprocess.bpmn";
@Rule
@Test
public void startProcess() throws Exception {
RepositoryService repositoryService = activitiRule.getRepositoryService();
repositoryService.createDeployment().addInputStream("myProcess.bpmn20.xml",
new FileInputStream(filename)).deploy();
Map<String, Object> variableMap = new HashMap<String, Object>();
variableMap.put("name", "Activiti");
ProcessInstance processInstance = runtimeService.startProcessInstanceByKey("myProcess", variableMap);
assertNotNull(processInstance.getId());
System.out.println("id " + processInstance.getId() + " " + processInstance.getProcessDefinitionId());
// Get Task
TaskService taskService = activitiRule.getTaskService();
Task task = taskService.createTaskQuery().taskUnassigned().singleResult();
assertNotNull(task.getId());
System.out.println("Task 1 id " + task.getId());
// Set Variable
taskService.setVariable(task.getId(), "var_name", "var_value");
// Get Task by variable
Task task2 = taskService.createTaskQuery().taskVariableValueEquals("var_name", "var_value").singleResult();
assertNotNull(task2.getId());
System.out.println("Task 2 id " + task2.getId());
The result is FAIL!!!???Thanks.
