Obsolete Pages{{Obsolete}}
The official documentation is at: http://docs.alfresco.com
{{AVMWarning}}
Overview
The deployment receiver engine is the top level object in any deployment receiver, be it AVM, DM, or filesystem. It binds together all the components necessary to function as a deployment server capable of receiving files from an authoring server. Note that this bean has no means to specify the manner in which its methods are invoked: it is 'transport agnostic'. Configuration of Java RMI, Spring HTTP or a custom transport is taken care of separately. This bean does, however, need to know whether it is running within the Alfresco server or not, via the daemonThread property.
- Interface :
org.alfresco.deployment.DeploymentReceiverTransport
- Interface :
org.alfresco.deployment.DeploymentReceiverService
- Implementation :
org.alfresco.deployment.impl.server.DeploymentReceiverEngineImpl
Configurable Property Reference
Property
| Type
| Description
| transformers | list of transformers | (details) list of content transformers to apply to the incoming data. |
| housekeepers | set of housekeepers | Housekeepers are called periodically to detect problems and tidy up. |
| pollDelay | integer | interval (in seconds?) between calls to housekeepers |
| commandQueue | bean reference | Link to the backlog of commands for this deployment engine. |
| readerManagement | bean reference | Link to the stream management bean (simple, pooled, etc.) See configuration files |
| authenticator | bean reference or definition | Link to the authentication bean to be used when shutting down this deployment engine. NOTE: this is only necessary for the stand-alone configuration. This property can be omitted from the configuration when the deployment receiver engine will be running within Alfresco. |
| daemonThread | boolean | If true, indicates that engine is running within Alfresco. If false, indicates stand-alone mode and causes a 'keepalive' thread to start. |
See also
Community Edition
3.2
3.2r2
AVM
