Hello,We have a process, that finishes with a service task (db update). [img]http://abload.de/img/capturedzrhx.png[/img]In there, we used runtimeService.setVariable(); to set another variable, if the database update was successfull or not.(this method is called by the service task):
public void updateContractEntity() throws RESTOperationFailedException, ReservedValueUsedException {
// Post changes back to EntityStore.
log.f(getClass(), "Updating Contract Entity in EntityStore.");
EntityAdapter ea = null;
try {
ea = new EntityAdapter(oceProcessService.getProcessKey(businessProcess.getProcessInstance()));
ea.update("contract", processVariableMap, new Date());
runtimeService.setVariable(businessProcess.getProcessInstance().getProcessInstanceId(), "dbUpdated", true);
} catch (ConfigurationException e) {
// Rethrow.
throw new RESTOperationFailedException(e);
This causes the following problem:When the process is completed, he is shown as RUNNING and Completed. (i.e. both, the historicService and the runtimeService are returning this process, when using the processQuery)We noticed the following database inconsistences are generated:- Activitii dropped ALL Variables from the ACT_RU_VARIABLE, except the one that has been set above. (dbUpdated) (I assume, that activiti IS flushing all the variables, and - while completing the transaction - creating the value.- Activiti setup the start- and endevent in ACT_HI_EXECUTION correctly.- Activiti did NOT delete everything from ACT_RU_EXECUTION. **In the log files we found that activiti was unable to delete the running execution, because the foreign key constraint with the ru_variable table failed:
### Error updating database. Cause: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Cannot delete or update a parent row: a foreign key constraint fails (`oce2`.`ACT_RU_VARIABLE`, CONSTRAINT `ACT_FK_VAR_EXE` FOREIGN KEY (`EXECUTION_ID_`) REFERENCES `ACT_RU_EXECUTION` (`ID_`))
### The error may involve org.activiti.engine.impl.persistence.entity.ExecutionEntity.deleteExecution-Inline
### SQL: delete from ACT_RU_EXECUTION where ID_ = ?
### Cause: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Cannot delete or update a parent row: a foreign key constraint fails (`mydb`.`ACT_RU_VARIABLE`, CONSTRAINT `ACT_FK_VAR_EXE` FOREIGN KEY (`EXECUTION_ID_`) REFERENCES `ACT_RU_EXECUTION` (`ID_`))
at org.apache.ibatis.session.defaults.DefaultSqlSession.update(DefaultSqlSession.java:147)
at org.apache.ibatis.session.defaults.DefaultSqlSession.delete(DefaultSqlSession.java:158)
at org.activiti.engine.impl.db.DbSqlSession$DeleteById.execute(DbSqlSession.java:146)
at org.activiti.engine.impl.db.DbSqlSession.flushDeletes(DbSqlSession.java:483)
at org.activiti.engine.impl.db.DbSqlSession.flush(DbSqlSession.java:371)
at org.activiti.engine.impl.interceptor.CommandContext.flushSessions(CommandContext.java:157)
at org.activiti.engine.impl.interceptor.CommandContext.close(CommandContext.java:109)
at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:49)
at org.activiti.engine.impl.interceptor.JtaTransactionInterceptor.execute(JtaTransactionInterceptor.java:59)
at org.activiti.engine.impl.TaskServiceImpl.complete(TaskServiceImpl.java:148)
at org.activiti.cdi.BusinessProcess.completeTask(BusinessProcess.java:350)
at my.namespace.controller.TaskViewController.completeTask(TaskViewController.java:268)
at my.namespace.controller.TaskViewController$Proxy$_$$_WeldClientProxy.completeTask(TaskViewController$Proxy$_$$_WeldClientProxy.java)
at org.apache.el.parser.AstValue.invoke(AstValue.java:262)
at org.apache.el.MethodExpressionImpl.invoke(MethodExpressionImpl.java:278)
at org.jboss.weld.util.el.ForwardingMethodExpression.invoke(ForwardingMethodExpression.java:39)
at org.jboss.weld.el.WeldMethodExpression.invoke(WeldMethodExpression.java:50)
at com.sun.faces.facelets.el.TagMethodExpression.invoke(TagMethodExpression.java:105)
at javax.faces.component.MethodBindingMethodExpressionAdapter.invoke(MethodBindingMethodExpressionAdapter.java:88)
at com.sun.faces.application.ActionListenerImpl.processAction(ActionListenerImpl.java:102)
at javax.faces.component.UICommand.broadcast(UICommand.java:315)
at javax.faces.component.UIViewRoot.broadcastEvents(UIViewRoot.java:794)
at javax.faces.component.UIViewRoot.processApplication(UIViewRoot.java:1259)
at com.sun.faces.lifecycle.InvokeApplicationPhase.execute(InvokeApplicationPhase.java:81)
at com.sun.faces.lifecycle.Phase.doPhase(Phase.java:101)
at com.sun.faces.lifecycle.LifecycleImpl.execute(LifecycleImpl.java:118)
at javax.faces.webapp.FacesServlet.service(FacesServlet.java:593)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:329)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:248)
at org.primefaces.webapp.filter.FileUploadFilter.doFilter(FileUploadFilter.java:77)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:280)
at org.jboss.weld.servlet.ConversationPropagationFilter.doFilter(ConversationPropagationFilter.java:62)
at org.togglz.servlet.TogglzFilter.doFilter(TogglzFilter.java:58)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:61)
at org.apache.shiro.web.servlet.AdviceFilter.executeChain(AdviceFilter.java:108)
at org.apache.shiro.web.servlet.AdviceFilter.doFilterInternal(AdviceFilter.java:137)
at org.apache.shiro.web.servlet.OncePerRequestFilter.doFilter(OncePerRequestFilter.java:125)
at org.apache.shiro.web.servlet.ProxiedFilterChain.doFilter(ProxiedFilterChain.java:66)
at org.apache.shiro.web.servlet.AbstractShiroFilter.executeChain(AbstractShiroFilter.java:449)
at org.apache.shiro.web.servlet.AbstractShiroFilter$1.call(AbstractShiroFilter.java:365)
at org.apache.shiro.subject.support.SubjectCallable.doCall(SubjectCallable.java:90)
at org.apache.shiro.subject.support.SubjectCallable.call(SubjectCallable.java:83)
at org.apache.shiro.subject.support.DelegatingSubject.execute(DelegatingSubject.java:380)
at org.apache.shiro.web.servlet.AbstractShiroFilter.doFilterInternal(AbstractShiroFilter.java:362)
at my.namespace.filters.UrlRewriteFilter.doFilter(UrlRewriteFilter.java:91)
at my.namespace.filters.EncodingFilter.doFilter(EncodingFilter.java:17)
at my.namespace.filters.NoCacheFilter.doFilter(NoCacheFilter.java:21)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:275)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:161)
at org.jboss.as.jpa.interceptor.WebNonTxEmCloserValve.invoke(WebNonTxEmCloserValve.java:50)
at org.jboss.as.web.security.SecurityContextAssociationValve.invoke(SecurityContextAssociationValve.java:153)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:155)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:368)
at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:877)
at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.java:671)
at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:930)
Caused by: com.mysql.jdbc.exceptions.jdbc4.MySQLIntegrityConstraintViolationException: Cannot delete or update a parent row: a foreign key constraint fails (`mydb`.`ACT_RU_VARIABLE`, CONSTRAINT `ACT_FK_VAR_EXE` FOREIGN KEY (`EXECUTION_ID_`) REFERENCES `ACT_RU_EXECUTION` (`ID_`))
at com.mysql.jdbc.Util.handleNewInstance(Util.java:407)
at com.mysql.jdbc.Util.getInstance(Util.java:382)
at com.mysql.jdbc.SQLError.createSQLException(SQLError.java:1040)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3603)
at com.mysql.jdbc.MysqlIO.checkErrorPacket(MysqlIO.java:3535)
at com.mysql.jdbc.MysqlIO.sendCommand(MysqlIO.java:1989)
at com.mysql.jdbc.MysqlIO.sqlQueryDirect(MysqlIO.java:2150)
at com.mysql.jdbc.ConnectionImpl.execSQL(ConnectionImpl.java:2626)
at com.mysql.jdbc.PreparedStatement.executeInternal(PreparedStatement.java:2119)
at com.mysql.jdbc.PreparedStatement.execute(PreparedStatement.java:1362)
at org.jboss.jca.adapters.jdbc.WrappedPreparedStatement.execute(WrappedPreparedStatement.java:404)
at org.apache.ibatis.executor.statement.PreparedStatementHandler.update(PreparedStatementHandler.java:41)
at org.apache.ibatis.executor.statement.RoutingStatementHandler.update(RoutingStatementHandler.java:66)
at org.apache.ibatis.executor.SimpleExecutor.doUpdate(SimpleExecutor.java:45)
at org.apache.ibatis.executor.BaseExecutor.update(BaseExecutor.java:108)
at org.apache.ibatis.executor.CachingExecutor.update(CachingExecutor.java:75)
at org.apache.ibatis.session.defaults.DefaultSqlSession.update(DefaultSqlSession.java:145)
… 77 more
