I'm trying to install the SDK Basic Amp example with the mmt tool, but I have a small problem :roll: :
a) I generate the AMP file with: ant -f build.xml
b) I execute: java -jar alfresco-mmt.jar install alfresco-sdk-custom-service.amp alfresco.war -verbose
Then, this is the result:
Installing AMP 'alfresco-sdk-custom-service.amp' into WAR 'alfresco.war'
WAR has been backed up to 'alfresco.war-1203616621417.bak'
No module.properties file has been found in the installing .amp file 'alfresco-s
I have to modify the build.xml?
Thanks anyway,
Javier
