Hi,i'm a new alfresco user and i have a problem with alfresco SDK.When i run SDK FirstFoundationClient eclipse project, i have this kind of error:12:21:23,764 Userystem WARN [remoting.rmi.RmiRegistryFactoryBean] Could not detect RMI registry - creating new one12:21:26,570 Userystem INFO [domain.schema.SchemaBootstrap] Schema managed by database dialect org.hibernate.dialect.MySQLInnoDBDialect.12:21:29,984 Userystem INFO [domain.schema.SchemaBootstrap] No changes were made to the schema.12:21:32,261 Userystem WARN [node.index.FullIndexRecoveryComponent] The indexes are not synchronized with the database.12:21:32,276 Userystem WARN [repo.admin.ConfigurationChecker] The Alfresco 'dir.root' property is set to a relative path '../alf_data'. 'dir.root' should be overridden to point to a specific folder.12:21:32,276 Userystem INFO [repo.admin.ConfigurationChecker] The Alfresco root data directory ('dir.root') is: ..\alf_data12:21:32,307 Userystem ERROR [repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: Indexes not found for 5 stores.12:21:32,307 Userystem INFO [repo.admin.ConfigurationChecker] You may set 'index.recovery.mode=FULL' if you need to rebuild the indexes.12:21:32,307 Userystem ERROR [repo.admin.ConfigurationChecker] CONTENT INTEGRITY ERROR: System content not found in content store.12:21:32,307 Userystem ERROR [repo.admin.ConfigurationChecker] Ensure that the 'dir.root' property is pointing to the correct data location.Exception in thread "main" org.alfresco.error.AlfrescoRuntimeException: Ensure that the 'dir.root' property is pointing to the correct data location. at org.alfresco.repo.admin.ConfigurationChecker.check(ConfigurationChecker.java:312) at org.alfresco.repo.admin.ConfigurationChecker.access$000(ConfigurationChecker.java:72) at org.alfresco.repo.admin.ConfigurationChecker$1.execute(ConfigurationChecker.java:178) at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:236) at org.alfresco.repo.transaction.RetryingTransactionHelper.doInTransaction(RetryingTransactionHelper.java:185) at org.alfresco.repo.admin.ConfigurationChecker.onBootstrap(ConfigurationChecker.java:182) at org.alfresco.util.AbstractLifecycleBean.onApplicationEvent(AbstractLifecycleBean.java:62) at org.springframework.context.event.SimpleApplicationEventMulticaster$1.run(SimpleApplicationEventMulticaster.java:77) at org.springframework.core.task.SyncTaskExecutor.execute(SyncTaskExecutor.java:49) at org.springframework.context.event.SimpleApplicationEventMulticaster.multicastEvent(SimpleApplicationEventMulticaster.java:75) at org.springframework.context.support.AbstractApplicationContext.publishEvent(AbstractApplicationContext.java:241) at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:349) at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:92) at org.springframework.context.support.ClassPathXmlApplicationContext.<init>(ClassPathXmlApplicationContext.java:77) at org.alfresco.util.ApplicationContextHelper.getApplicationContext(ApplicationContextHelper.java:55) at org.alfresco.sample.FirstFoundationClient.main(FirstFoundationClient.java:69)I LOOK AT ALSO AT http://issues.alfresco.com/browse/AR-1570 BUT WITHOUT RESULTS.CAN SOMEONE HELP ME PLEASE?
