Event Handlers are introduced In Activiti 5.15I want to execute custom logic when the TASK_ASSIGNED event is calledWhenever Task is Assigned to a user i want that Event listener should listen the TASK_ASSIGNED event and i want assignee(User) of task in the event TASK_ASSIGNEDI have created my Event Listener for that as below
public class MyEventListener implements ActivitiEventListener{
@Override
public boolean isFailOnException() {
return false;
@Override
public void onEvent(ActivitiEvent event) {
switch(event.getType()){
case TASK_ASSIGNED:
System.out.println("From Event handler TASK_ASSIGNED:");
TaskService ts = event.getEngineServices().getTaskService();
System.out.println("No of Task: " + ts.createTaskQuery().processInstanceId(event.getProcessInstanceId()).count());
List<Task> tasks = ts.createTaskQuery().processInstanceId(event.getProcessInstanceId()).list();
for(Task task : tasks)
System.out.println("Task Name: " + task.getName());
System.out.println("Task Assignee: " + task.getAssignee());
System.out.println("Task Description: " + task.getDescription());
break;
case TASK_COMPLETED:
System.out.println("From Event handler TASK_COMPLETED:");
TaskService ts2 = event.getEngineServices().getTaskService();
System.out.println("No of Task: " + ts2.createTaskQuery().processInstanceId(event.getProcessInstanceId()).count());
tasks = ts2.createTaskQuery().processInstanceId(event.getProcessInstanceId()).list();
break;
And I have generated Unit Test for Process
TaskService ts = activitiRule.getTaskService();
System.out.println("From Junit Test");
System.out.println("No of Tasks from UnitTest: " +ts.createTaskQuery().processInstanceId(processInstance.getId()).count() );
List<Task> tasks = ts.createTaskQuery().processInstanceId(processInstance.getId()).list();
ts.complete(task.getId());
OUTPUT of JUnit Test:
No of Task: 0
From Junit Test
No of Tasks from UnitTest: 1
Task Name: Approval
Task Assignee: kermit
Task Description: This is Simple Approval Task
No of Task: 1
Task Name: Approval
So when I Run The unit Test I got Result From TASK_COMPLETED and from Junit Test. But, in TASK_ASSIGNED: case I got list of Task = 0This may be because First Activiti call TASK_ASSIGNED event and then it update Activiti DB so when we query inside TASK_ASSIGNED we will get no of Task =0 But I want assignee in TASK_ASSIGNED event. so, when Task is assigned to user, I want to get that assignee and want to use some Custom logic on that Assignee Please Help me For this problem
