Hi, this is my first post in this forum.I have this code :
List<String> estados = new ArrayList<String>();
estados.add("Status 1");
estados.add("Status 2"); // etc
List<String> list = new ArrayList<String>();
HistoricProcessInstanceQuery hQuery = historyService.createHistoricProcessInstanceQuery().processDefinitionKey("process_pool1");
if(hQuery != null) {
for(String estado : estados) {
List<HistoricProcessInstance> hProcess = hQuery.finished()
.includeProcessVariables()
.variableValueEquals("estado", estado).list();//.listPage(offset, limit);
if(hProcess != null && hProcess.size() > 0) {
for(HistoricProcessInstance hInst : hProcess) {
//System.out.println((String)hInst.getProcessVariables().get("variable"));
list.add((String)hInst.getProcessVariables().get("variable"));
// Reinstante it or it won't work…
The problem is in the next line
I have two finished tasks with the status "Status 1". If I try listPage(0, 10)
it returns nothing. If I try listPage(10, 10)
it returns nothing.if I try listPage(20, 10)
it returns one of the two records…The thing is simple, there's something wrong with that method, or I don't know how to use it. If I have two records with those conditions, then the first listPage (0, 10) should return them, but it doesn't. For now I'm using list() to return them all, but I need to use it in a pagination, but it's not working. If I search in ACT_HI_VARINST for NAME_='estado' AND TEXT_='Status 1' I get the two records.I'm using activiti 5.13Thanks in advance. I can't post more code, this is from my work.
