In my application, I have lots of fixed variables in process and task. So when I retrieve them from act_ru_task and act_ru_variable table it is a performance hit. So I am thinking of putting a trigger when insert /update/delete happens in act_ru_variable. In order to do that I should be knowing flow of when insert/update/delete happens in different cases like parallel gateway , subprocess, so that I can write my own trigger working properly.
Shweta
