Hi, I have wrote a simple activiti junit as below. Trying to 'run as Junit' via eclipse. I am getting exception as below. Please can someone help me. I know I am missing something at very basic level. Please note I have included all jars in my project from activiti-5.14\libs.Exception Below:-
java.lang.NoClassDefFoundError: org/junit/rules/TestRule
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at java.security.SecureClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.defineClass(Unknown Source)
at java.net.URLClassLoader.access$100(Unknown Source)
at java.net.URLClassLoader$1.run(Unknown Source)
at java.net.URLClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.misc.Launcher$AppClassLoader.loadClass(Unknown Source)
at java.lang.Class.getDeclaredFields0(Native Method)
at java.lang.Class.privateGetDeclaredFields(Unknown Source)
at java.lang.Class.getDeclaredFields(Unknown Source)
at org.junit.runners.model.TestClass.<init>(TestClass.java:40)
at org.junit.runners.ParentRunner.<init>(ParentRunner.java:65)
at org.junit.runners.BlockJUnit4ClassRunner.<init>(BlockJUnit4ClassRunner.java:59)
at org.junit.internal.builders.JUnit4Builder.runnerForClass(JUnit4Builder.java:13)
at org.junit.runners.model.RunnerBuilder.safeRunnerForClass(RunnerBuilder.java:57)
at org.junit.internal.builders.AllDefaultPossibilitiesBuilder.runnerForClass(AllDefaultPossibilitiesBuilder.java:29)
at org.junit.internal.requests.ClassRequest.getRunner(ClassRequest.java:24)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestReference.<init>(JUnit4TestReference.java:33)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestClassReference.<init>(JUnit4TestClassReference.java:25)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.createTest(JUnit4TestLoader.java:48)
at org.eclipse.jdt.internal.junit4.runner.JUnit4TestLoader.loadTests(JUnit4TestLoader.java:38)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:452)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.runTests(RemoteTestRunner.java:683)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.run(RemoteTestRunner.java:390)
at org.eclipse.jdt.internal.junit.runner.RemoteTestRunner.main(RemoteTestRunner.java:197)
Caused by: java.lang.ClassNotFoundException: org.junit.rules.TestRule
… 31 more
import org.activiti.engine.test.Deployment;
import org.junit.Rule;
import org.junit.Test;
public class TestMyProcess{
@Rule
@Test
@Deployment
public void testMyProcess()
runtimeService.startProcessInstanceByKey("myProcess");
System.out.println("Completed Test Activiti");
My Simple myProcess.bpmn20.xml is below:
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
<process id="myProcess" name="My process" isExecutable="true">
<serviceTask id="servicetask1" name="Service Task" activiti:class="com.companyName.activiti.common.JavaActService1"></serviceTask>
<sequenceFlow id="flow1" sourceRef="startevent1" targetRef="servicetask1"></sequenceFlow>
<sequenceFlow id="flow2" sourceRef="servicetask1" targetRef="endevent1"></sequenceFlow>
</process>
<bpmndi:BPMNDiagram id="BPMNDiagram_myProcess">
<bpmndi:BPMNPlane bpmnElement="myProcess" id="BPMNPlane_myProcess">
<bpmndi:BPMNShape bpmnElement="startevent1" id="BPMNShape_startevent1">
<omgdc:Bounds height="35.0" width="35.0" x="350.0" y="200.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="servicetask1" id="BPMNShape_servicetask1">
<omgdc:Bounds height="55.0" width="105.0" x="600.0" y="190.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<omgdc:Bounds height="35.0" width="35.0" x="930.0" y="200.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<omgdi:waypoint x="385.0" y="217.0"></omgdi:waypoint>
<omgdi:waypoint x="600.0" y="217.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<omgdi:waypoint x="705.0" y="217.0"></omgdi:waypoint>
<omgdi:waypoint x="930.0" y="217.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
</bpmndi:BPMNPlane>
</bpmndi:BPMNDiagram>
</definitions>
I am having proceeses.xml with above bpmn xml file as below:
<?xml version="1.0" encoding="utf-8" ?>
<processes>
<process resource="diagrams/MyProcess.bpmn20.xml" />
</processes>
Some basic question. Please help. Do I need to put some code somewhere in my junit class similar to:<b>repositoryService.createDeployment().addClasspathResource("org/activiti/test/VacationRequest.bpmn20.xml").deploy();<b>If not, How do the junit deploy the process otherwise. If yes, please help how to do so.Thanks in advance for any help.
