Hello, when running a simple test case and setting a service task to async it does not execute my Service classThis is the workflow:
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
<process id="myProcess" name="My process" isExecutable="true">
<serviceTask id="servicetask1" name="Some Service" activiti:async="true" activiti:class="RunService"></serviceTask>
<sequenceFlow id="flow1" sourceRef="startevent1" targetRef="servicetask1"></sequenceFlow>
<sequenceFlow id="flow2" sourceRef="servicetask1" targetRef="endevent1"></sequenceFlow>
</process>
<bpmndi:BPMNDiagram id="BPMNDiagram_myProcess">
<bpmndi:BPMNPlane bpmnElement="myProcess" id="BPMNPlane_myProcess">
<bpmndi:BPMNShape bpmnElement="startevent1" id="BPMNShape_startevent1">
<omgdc:Bounds height="35.0" width="35.0" x="290.0" y="130.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<omgdc:Bounds height="35.0" width="35.0" x="600.0" y="130.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<bpmndi:BPMNShape bpmnElement="servicetask1" id="BPMNShape_servicetask1">
<omgdc:Bounds height="55.0" width="105.0" x="420.0" y="120.0"></omgdc:Bounds>
</bpmndi:BPMNShape>
<omgdi:waypoint x="325.0" y="147.0"></omgdi:waypoint>
<omgdi:waypoint x="420.0" y="147.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
<omgdi:waypoint x="525.0" y="147.0"></omgdi:waypoint>
<omgdi:waypoint x="600.0" y="147.0"></omgdi:waypoint>
</bpmndi:BPMNEdge>
</bpmndi:BPMNPlane>
</bpmndi:BPMNDiagram>
</definitions>
This is the service class:
import org.activiti.engine.impl.pvm.delegate.ActivityBehavior;
import org.activiti.engine.impl.pvm.delegate.ActivityExecution;
public class RunService implements ActivityBehavior {
public void execute(ActivityExecution arg0) throws Exception {
System.out.println("executing RunService");
and this is the unit test:
package test.java.org.activiti.designer.test;
import static org.junit.Assert.assertNotNull;
import java.io.FileInputStream;
import java.util.HashMap;
import java.util.Map;
import org.activiti.engine.RepositoryService;
import org.activiti.engine.runtime.ProcessInstance;
import org.junit.Rule;
import org.junit.Test;
public class ProcessTestMyProcess {
private String filename = "/resources/TestAsync.bpmn";
@Rule
@Test
public void startProcess() throws Exception {
RepositoryService repositoryService = activitiRule.getRepositoryService();
repositoryService.createDeployment().addInputStream("myProcess.bpmn20.xml",
new FileInputStream(filename)).deploy();
Map<String, Object> variableMap = new HashMap<String, Object>();
variableMap.put("name", "Activiti");
ProcessInstance processInstance = runtimeService.startProcessInstanceByKey("myProcess", variableMap);
assertNotNull(processInstance.getId());
System.out.println("id " + processInstance.getId() + " "
+ processInstance.getProcessDefinitionId());
When setting to activiti:async="true", the service class is never called (no println and no debugger breakpoint work here), setting it to false does make it get called. Am I misunderstanding how async should work here and is there a way for a unit test to work with async = true ?Thank you.
