Hello , this is my first post and I am a newbie at Activiti.Iam using Activiti 5.10 /Camel 2.10Here is my Application definition:I have Camel deployed on tomcat 6.0.18 . I read records in an .csv file, split them and convert to an xml .After conversion using jaxb, they are sent to an active MQ queue.No issues so far.I have Activiti deployed on another tomcat instance(different port) and have used camel to receive the message from the same ActiveMQ and start a process.I have added all the relevant Camel and camel related jars to the activiti-explorer /WEB-INF/lib folder and able to start tomcat and see that camel is also starting(similar to server1)I followed the example in the Activiti in Action and got the error:type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
javax.servlet.ServletException: org.springframework.beans.factory.NoSuchBeanDefinitionException: No unique bean of type [org.activiti.explorer.ExplorerApp] is defined: expected single bean but found 0:
com.vaadin.terminal.gwt.server.AbstractApplicationServlet.handleServiceException(AbstractApplicationServlet.java:999)
com.vaadin.terminal.gwt.server.AbstractApplicationServlet.service(AbstractApplicationServlet.java:548)
javax.servlet.http.HttpServlet.service(HttpServlet.java:717)
root cause
org.springframework.beans.factory.support.DefaultListableBeanFactory.getBean(DefaultListableBeanFactory.java:280)
org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1106)
org.activiti.explorer.servlet.ExplorerApplicationServlet.getNewApplication(ExplorerApplicationServlet.java:55)
com.vaadin.terminal.gwt.server.AbstractApplicationServlet.createApplication(AbstractApplicationServlet.java:973)
com.vaadin.terminal.gwt.server.AbstractApplicationServlet.findApplicationInstance(AbstractApplicationServlet.java:801)
com.vaadin.terminal.gwt.server.AbstractApplicationServlet.service(AbstractApplicationServlet.java:456)
Here is my camel-application-context.xml file:<?xml version="1.0" encoding="UTF-8"?>
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:camel="http://camel.apache.org/schema/spring"
xsi:schemaLocation="http://www.springframework.org/schema/beans http://www.springframework.org/schema/beans/spring-beans.xsd
http://camel.apache.org/schema/spring http://camel.apache.org/schema/spring/camel-spring.xsd">
<bean id="activemq" class="org.apache.activemq.camel.component.ActiveMQComponent">
<property name="brokerURL" value="tcp://localhost:61616" /></bean>
<bean id="camel" class="org.activiti.camel.CamelBehaviour">
<constructor-arg index="0">
<list>
<bean class="org.activiti.camel.SimpleContextProvider">
<constructor-arg index="0" value="PaymentActivitiProcess" />
<constructor-arg index="1" ref="camelProcess" />
</bean>
</list>
</constructor-arg>
</bean>
<camelContext id="camelProcess" xmlns="http://camel.apache.org/schema/spring">
<packageScan>
<package>com.spalamadai.payments.activiti.camel</package>
</packageScan>
</camelContext>
</beans>
This along with the activiti-application-context.xml and camel-application-context.xml are packaged ina jar file copied to the activiti-explorer/WEB-INF/lib folderMy workflow file:<?xml version="1.0" encoding="UTF-8"?>
<definitions xmlns="http://www.omg.org/spec/BPMN/20100524/MODEL" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:activiti="http://activiti.org/bpmn" xmlns:bpmndi="http://www.omg.org/spec/BPMN/20100524/DI" xmlns:omgdc="http://www.omg.org/spec/DD/20100524/DC" xmlns:omgdi="http://www.omg.org/spec/DD/20100524/DI" typeLanguage="http://www.w3.org/2001/XMLSchema" expressionLanguage="http://www.w3.org/1999/XPath" targetNamespace="http://www.activiti.org/test">
<process id="PaymentActivitiProcess" name="PaymentActivitiProcess">
<serviceTask id="servicetask1" name="Receive Payment" activiti:delegateExpression="${camel}"></serviceTask>
<sequenceFlow id="flow1" name="to Service Task" sourceRef="startevent1" targetRef="servicetask1"></sequenceFlow>
<serviceTask id="servicetask2" name="Service Task" activiti:class="com.spalamadai.payments.activiti.delegate.PaymentsDelegateBean"></serviceTask>
<sequenceFlow id="flow2" name="to Service Task" sourceRef="servicetask1" targetRef="servicetask2"></sequenceFlow>
<sequenceFlow id="flow3" name="to End" sourceRef="servicetask2" targetRef="endevent1"></sequenceFlow>
</process>My activiti-explorer web.xml:<?xml version="1.0" encoding="UTF-8"?>
<web-app xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns="http://java.sun.com/xml/ns/javaee" xmlns:web="http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd"
xsi:schemaLocation="http://java.sun.com/xml/ns/javaee http://java.sun.com/xml/ns/javaee/web-app_2_5.xsd"
id="WebApp_ID" version="2.5">
<display-name>Vaadin Web Application</display-name>
<context-param>
<description>Vaadin production mode</description>
<param-name>productionMode</param-name>
<param-value>true</param-value>
</context-param>
<context-param>
<param-name>contextConfigLocation</param-name>
<param-value>classpath*:application-context.xml</param-value>
</context-param>
<!– To load the Spring context –>
<listener>
<listener-class>org.springframework.web.context.ContextLoaderListener</listener-class>
</listener>
<!– To allow session-scoped beans in Spring –>
<listener>
<listener-class>org.springframework.web.context.request.RequestContextListener</listener-class>
</listener>
<servlet>
<servlet-name>Vaadin Application Servlet</servlet-name>
<servlet-class>org.activiti.explorer.servlet.ExplorerApplicationServlet</servlet-class>
</servlet>
<servlet-mapping>
<url-pattern>/*</url-pattern>
</servlet-mapping>
<!– Session timeout on one day –>
<session-config>
<session-timeout>480</session-timeout>
</session-config>
</web-app>
Note: I have NOT changed the activiti-ui-context.xml and the applicationContext.xml file in activiti-explorer/WEB_INF folder.If I comment out the [b]<context-param>
</context-param>[/b]
section, I can open the Activiti Explorer application and deploy the workflow. But on un-commenting the above section, i am not able to process the message from the queue due to this error:21 Dec 2012 00:34:34,610 [Camel (camelProcess) thread #0 - JmsConsumer[singlePayment]] ERROR org.slf4j.helpers.MarkerIgnoringBase:161 - Failed delivery for (MessageId: ID:MWKS331733-53204-1356071672311-1:3:1:1:1 on ExchangeId: ID-MWKS331733-53191-1356071653002-0-2). Exhausted after delivery attempt: 1 caught: org.activiti.engine.ActivitiException: no processes deployed with key 'PaymentActivitiProcess'org.activiti.engine.ActivitiException: no processes deployed with key 'PaymentActivitiProcess' at org.activiti.engine.impl.persistence.deploy.DeploymentCache.findDeployedLatestProcessDefinitionByKey(DeploymentCache.java:63) at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:58) at org.activiti.engine.impl.cmd.StartProcessInstanceCmd.execute(StartProcessInstanceCmd.java:31) at org.activiti.engine.impl.interceptor.CommandExecutorImpl.execute(CommandExecutorImpl.java:24) at org.activiti.engine.impl.interceptor.CommandContextInterceptor.execute(CommandContextInterceptor.java:42)Any help will be greatly appreciated.
