Hello,[using Alf 210E]I've built a webscript to upload files. Everything works as expected, I just can't set the right content encoding.The relevant lines of javascript:
// create document in folder for uploaded file
upload = uploadFolder.createFile(filename) ;
upload.properties.content.write(content);
//set correct mimetype and encoding
upload.properties.content.mimetype = uploadMimeType;
upload.properties.content.encoding = "UTF-8";
upload.properties.title = title;
upload.properties.description = description;
upload.save();
Alfresco throws an error on the line where i set the encoding to UTF-8:
Failed to execute script 'workspace://SpacesStore//Company Home/Data Dictionary/Web Scripts/klm/klmupload.post.js': Failed to execute script 'workspace://SpacesStore//Company Home/Data Dictionary/Web Scripts/klm/klmupload.post.js': Java class "org.alfresco.repo.jscript.ScriptNode$ScriptContentData" has no public instance field or method named "encoding". (AlfrescoScript#50)
According to the Javascript documentation in the code, this property should be there. I've checked the source code (org.alfresco.repo.jscript.ScriptNode.java) and haven't found a setter/getter for the encoding on ScriptContentData. Is this a bug (didn't find it on JIRA) or am I missing something?Cheers,Roeland.
