avax.faces.FacesException: Could not retrieve value of component with path : {Component-Path : [Class: javax.faces.component.UIViewRoot,ViewId: /jsp/wcm/browse-website.jsp][Class: javax.faces.component.html.HtmlForm,Id: website][Class: org.alfresco.web.ui.common.component.UIPanel,Id: staging-panel][Class: javax.faces.component.html.HtmlOutputText,Id: _idJsp22]}caused by:org.apache.jasper.JasperException: Could not retrieve value of component with path : {Component-Path : [Class: javax.faces.component.UIViewRoot,ViewId: /jsp/wcm/browse-website.jsp][Class: javax.faces.component.html.HtmlForm,Id: website][Class: org.alfresco.web.ui.common.component.UIPanel,Id: staging-panel][Class: javax.faces.component.html.HtmlOutputText,Id: _idJsp22]}caused by:javax.faces.FacesException: Could not retrieve value of component with path : {Component-Path : [Class: javax.faces.component.UIViewRoot,ViewId: /jsp/wcm/browse-website.jsp][Class: javax.faces.component.html.HtmlForm,Id: website][Class: org.alfresco.web.ui.common.component.UIPanel,Id: staging-panel][Class: javax.faces.component.html.HtmlOutputText,Id: _idJsp22]}caused by:javax.faces.el.EvaluationException: Cannot get value for expression '#{AVMBrowseBean.stagingSummary}'caused by:javax.faces.el.EvaluationException: Exception getting value of property stagingSummary of base of type : org.alfresco.web.bean.wcm.AVMBrowseBeancaused by:javax.faces.el.EvaluationException: Bean: org.alfresco.web.bean.wcm.AVMBrowseBean, property: stagingSummarycaused by:java.lang.reflect.InvocationTargetExceptioncaused by:java.lang.IllegalArgumentException: unknown format type at
